Register •
FAQ
• Login
It is currently Fri Nov 22, 2024 9:54 pm
[ 6 posts ] |
TOOLMAN
EFI Air Filters
I'm trying to find an alternative to ordering my air filter through BC Broncos. Searching a little this morning and found this one:
Any opinions? I wanted something maybe a little shorter and one that had a number that I could cross reference to something! i obviously wanted to stay away from the oily filters.
Thu Mar 23, 2017 9:41 am |
EFI Air Filters
Iam just using a generic cone filter but it has a opening at the end and sides. Like this one. https://www.ebay.com/itm/331822698357After reading a ton I didn't see much of a difference between the expensive ones or cheaper ones. I use a heavier more dense mesh one on the 69 due to it having open fender wells and being a more traditional circle up top air filter. I clean it a few times a year.
Thu Mar 23, 2017 1:56 pm |
Re: EFI Air Filters
I've used AEM dry-flow filters in the past and I recommend them. I like that they are cleanable and do not require the proper dosage of oil to filter the air. I think what you linked to would be just fine!
Thu Mar 23, 2017 2:48 pm |
darkmagus
Joined: Wed Mar 09, 2011 10:47 pm Posts: 57 Location: Englewood
Re: EFI Air Filters
I've been looking for one too. I'm probably going with something like this. Just wish it didn't have green foam. https://www.amazon.com/dp/B009NM7UGI/re ... 1ybVB4YM1Y
Thu Mar 23, 2017 7:08 pm |
Re: EFI Air Filters
I wouldn't run foam. They degrade over time and get sucked into the engine. The AEM dry flow is a great choice.
Thu Mar 23, 2017 7:16 pm |
TOOLMAN
Re: EFI Air Filters
Thanks for the responses fellas....parts on order.
Fri Mar 24, 2017 7:17 am |
[ 6 posts ] |
Users browsing this forum: No registered users and 44 guests |
