www.ColoradoClassicBroncos.com - View topic - Best supplier of collapsible steering shaft
It is currently Fri Nov 22, 2024 9:38 pm
Reply to topic  [ 21 posts ]
Post Best supplier of collapsible steering shaft
I have my 4x4x2 box installed & my upper column. I was going to make a collapsible steering shaft from the 79 Bronco shaft, but I've decided I should just buy one premade.
What is the best route for getting one. I saw WH makes them to order. Any other suggestions?
Sun Apr 02, 2017 5:25 pm
Post Re: Best supplier of collapsible steering shaft
Mine is from WH, so that's my vote..
Sun Apr 02, 2017 7:05 pm
I got mine from WH and they are quality.
Sun Apr 02, 2017 7:45 pm
Stock 76 upper with a lower made from a solid d shaft on mine. Ended up being about 2/3 the cost of the WH unit.
Sun Apr 02, 2017 8:59 pm
Mine is from Wild Horses, I think they are actually made by Flaming River.
Sun Apr 02, 2017 9:07 pm
Thanks. Found Toms has them too, but I'm leaning towards WH. Looks a little nicer than Toms.
Sun Apr 02, 2017 11:14 pm
WH is my vote
Mon Apr 03, 2017 10:24 am
Also got mine from WH.....no issues since install and it's a beefy unit.
Mon Apr 03, 2017 1:44 pm
I went tom's on mine since I have tom's box.
Mon Apr 03, 2017 1:58 pm
Does this help ?
http://classicbroncos.com/forums/showth ... p?t=276026
Thu Apr 06, 2017 6:34 pm
I don't think so. I'm pretty sure the 4x4x2 box has a different size input than the stock box. I'm going to double check now.
Thu Apr 06, 2017 6:53 pm
Thu Apr 06, 2017 7:06 pm
3/4" x 36 spline vs 13/16" x 36 spline for the stock stuff.
Thu Apr 06, 2017 7:07 pm
I was looking at that one too. I have a stock box but a 73-75 column so Viperwolf said that lower would not work.
Thu Apr 06, 2017 7:10 pm
I *think* I figured a cheapo way out of this. I have a 3/4"x36 (x2) ujoint I was given years ago. This will fit the 4x4x2 box and the lower part of the 79 Bronco collapsible shaft. The upper part of the lower shaft is probably 3/4"DD. I need to double check the 3/4"DD measurements against Borgeson's info, my battery died in my calipers. If it is 3/4"DD, I can add a universal 1"DD above it, and a 1"DD x 3/4"x36 ujoint to attach at my upper steering shaft. Pics to come, if this works. It will save me about $100, since I already have the lower ujoint. Summit has slightly better prices than Borgeson direct. If you buy 2 ujoints & the 1"DD shaft, you are almost the same price as buying Toms or WH, so no reason to do this.
http://www.borgeson.com/xcart/product.p ... =19&page=1
http://www.borgeson.com/xcart/product.p ... =67&page=1
3/4"DD & 1"DD measurments are on the bottom of page 4 here:
http://www.borgeson.com/Images/100th_Catalog.pdf
Thu Apr 06, 2017 10:22 pm
Thu Apr 06, 2017 10:59 pm
FYI. My upper is 3/4" 36 spline. It was a Tom's P/S conversion kit from 15+ years ago. Not sure if that was a stock configuration, or something Toms was having made. I can't even remember if the upper was part of the kit.
The catalog link I posted above has all their u-joints listed, you can find about any combo, like Viper said.
Thu Apr 06, 2017 11:02 pm
It may be 36.
Thu Apr 06, 2017 11:07 pm
Thu Apr 06, 2017 11:19 pm
Thu Apr 06, 2017 11:25 pm
My plan worked out. Only used 8.25" of the 1"DD tubing. This could be an affordable option if you have the 78/79 steering shaft & the lower joint is good. I removed the original because I had the new one, but if the old one was ok, you'll just need the 1"DD tube & upper joint. Even used the 78/79 boot between the two halves of the collapsible shaft. Will get it painted & installed soon. Need to paint the 4x4x2 box, and a few other odds & ends.
Sun May 14, 2017 6:08 pm
Users browsing this forum: Google [Bot] and 51 guests
32,958,869 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
