www.ColoradoClassicBroncos.com - View topic - What is this, track bar?
It is currently Fri Nov 22, 2024 9:23 pm
Reply to topic  [ 12 posts ]
Post What is this, track bar?
Any tricks on getting side 2 into the hole? 4 hours of Messing around and I'm stumped.
Sat Apr 29, 2017 4:08 pm
Unfortunately you need to readjust the whole setup, if not you're going to have the dreaded front end lean. So pull the radius arm that is currently installed out and pull the axle fwd so both radius arms are free to move in relationship to a level'ish surface. Next loosen all the radius arm cap bolts and retighten slowly watching that both arms stay at the same plane, i.e. stay in contact with the floor or at least stay parallel with each other. Hope all that makes sense, I think there is a tech article on WH website.
http://www.wildhorses4x4.com/product/br ... n/tech_faq
Sat Apr 29, 2017 4:55 pm
Post Re: What is this, track bar?
Sat Apr 29, 2017 5:14 pm
You should be able to disconnect the front axle from the frame by disconnecting the drag link. Then you can move the entire axle as one piece to slide both radius arms in together. Then reconnect the drag link.
Sat Apr 29, 2017 5:37 pm
Sat Apr 29, 2017 6:37 pm
One more question... the four bolts at the C Bushings. Should the radius arm and the end cap actually be flush against each other once it's all tightened up, or is it normal for there to be a small gap with these big bushings? I wasn't sure, but I do know the wrenching was getting tough!
Sat Apr 29, 2017 7:21 pm
There shouldn't be a gap.
Sat Apr 29, 2017 8:01 pm
Another question, and thanks for being patient. I'm not the seasoned vets like so many here. Learning. maybe Someday...
Anyway, would it make sense to put the wheels on the axle after its free and wheeling it into place?
Tell me what this guy is doing wrong (because I'm basically following his lead): https://www.youtube.com/watch?v=l1y5D6PvhDk
Sat Apr 29, 2017 8:47 pm
the wheels would make it easier. If you pull the trac-bar you'll be able to pull the axle forward enough to slide that in. I've also used a come along off the axle to the front bumper to pull it forward with out pulling the trac-bar.
Sun Apr 30, 2017 7:01 am
Images: 11
Sun Apr 30, 2017 8:07 am
Dish soap works well too. Allot of it.
Sun Apr 30, 2017 8:36 am
Turned out I had a C-Bushing upside down! I think that was the main culprit! Also greased it up heavily and it slid right in, no fight at all. Thanks for your help, everyone!
Sun Apr 30, 2017 12:13 pm
Users browsing this forum: No registered users and 49 guests
32,958,184 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
