It is currently Fri Nov 22, 2024 9:32 pm
Re: My Engine rebuild
I actually don't know what heads they are... how bad is that?
What a generous club! I'll keep you all posted!
I have gt40 intake. Are the heads a plug and play operation? I'm inclined to do what cheapest at this point... I gotta stop the wallet bleed!
Sun Apr 30, 2017 7:48 pm |
cpldavis37
If your motor is stock then E7s should be ok. One of my sets have crane roller rockers, but maybe they all did, I have no idea.
Sun Apr 30, 2017 9:55 pm |
The stop leak will arrive at my dad's tuesday. Once he has it, I should have a verdict in about 15 minutes if he has success...
BTW - can everyone see the start-up video? I never know if Google allows others to view or not.
Mon May 01, 2017 10:34 am |
Good luck-- I too have the old E7 heads-- you are free to them as well (I will even throw in a free 3 spd with it!).
The video worked for me. I dig that over the tire step stool. I have never seen anything like that!
Mon May 01, 2017 10:39 am |
Mon May 01, 2017 11:39 am |
BTW - here is a similar tire step to what we used. It matches the same dimensions: https://mobiledistributorsupply.com/249 ... aQodIOUKawAdditionally, my dad calls the local Napa, "Mañana auto parts" and it holds true. Irontite makes three different types of coolant stop leak and two of the three came in yesterday, just not the one I wanted!!! Perhaps today!
Wed May 03, 2017 8:44 am |
I am thinking I need to be picking up a set of heads for "just in case". So I am looking to see of the ones offered, which I should try to pickup. cpldavis37's has some upgrades that might be nice... But it may just come down to geographics, who's local to someone I can get them from.
Thu May 04, 2017 11:30 am |
Thu May 04, 2017 11:54 am |
Just FYI, this is the cracked head after the irontite all weather stop leak:
under black light
I'd love your input on this, and also what you think might have happened. I talked to the machine shop and they say it's unlikely the head was cracked when it left their shop as they use some process to check it for cracks...
Thu May 04, 2017 3:28 pm |
cpldavis37
Just let me know if you want them. No hurry they are just sitting in my garage.
Fri May 05, 2017 8:37 am |
Fri May 05, 2017 8:52 am |
Fri May 05, 2017 11:28 am |
Fri May 05, 2017 8:54 pm |
Justin if you and TJ can easily make the connection, that would be awesome. If not don't sweat it.
What's your schedule in Pueblo? I'll see if it lines up with my in-laws.
Otherwise wheatridge is fine and I'll get them at a later date.
Sat May 06, 2017 7:08 am |
I usually land at work on the south side of town around 9 and head back to denver between 2 and 3.
Sat May 06, 2017 8:27 am |
Just grind on it to clean it up and some JB weld on it.....
Sat May 06, 2017 9:18 pm |
I think I'll pull the header off and see where that crack goes. I may try to carve a small valley out and JB weld it if I think that will be successful.
Sun May 07, 2017 10:23 am |
Sun May 07, 2017 10:37 am |
cpldavis37
I can pull them off and meet up with Justin. I'll pm Justin and get his address
Sun May 07, 2017 4:40 pm |
TJ - thanks man!! I'd be happy to pay for something...you let me know.
Justin - Would it be better for you to have my inlaws meet you or to drop them off at Kenworth? And same to you, if you need some gas/beer money...
Mon May 08, 2017 6:08 am |
My company pays my mileage, no $$ needed. Where's kenwortg? If they can bring them, that'd be ideal. I'm just off i25.
Mon May 08, 2017 8:06 pm |
Mon May 08, 2017 8:18 pm |
I'll be on the south side of town, so my work sounds like it's better for all involved.
Mon May 08, 2017 8:24 pm |
Do we have any updates on the acquisition of these heads? If it doesn't work this time there is a backup location.
Tue May 16, 2017 7:49 am |
cpldavis37
I need to meet up with Justin or I can deliver them somewhere I just need to know where.
Tue May 16, 2017 7:53 pm |
I may be delaying my Pueblo run till next week depending on how this storm shapes up. Not really interested in turning a 2 hour drive into a 4 hour one.
Tue May 16, 2017 8:41 pm |
That's fine. My only push is that I'll be in CO for about a week starting thursday the 18th and have the ability to bring them home. But it's not critical so if that doesn't work. At that point I only need to get them to Federal and 38th at your convenience. From there I can have family get them to where they need to be.
Wed May 17, 2017 5:10 am |
Definitely pushing the Pueblo run back to next week. Not sure yet which day it'll happen.
Thu May 18, 2017 10:19 pm |
Fri Jun 16, 2017 10:04 am |
I'll be in Thornton Monday and Wednesday this week. I'll be in Pueblo on Friday
Sun Jun 18, 2017 8:38 pm |
Users browsing this forum: No registered users and 54 guests |
