www.ColoradoClassicBroncos.com - View topic - Post-lift issue
It is currently Fri Nov 22, 2024 9:25 pm
Reply to topic  [ 9 posts ]
 Post-lift issue
Post Post-lift issue
So if you've been following along on the forum, you're probably noticing that I'm a total amateur trying to lift my bronco. :)
So I replaced the bushings, installed the 2.5 Wild Horses lift... and now I'm noticing that the wheel on the driver's side extends out a noticeable amount compared to the passenger side. Any thoughts or ideas?
Thanks
Mon May 08, 2017 9:45 am
Post Re: Post-lift issue
After lifting, the stock track bar/mounts will pull the axle to the driver's side. You will need to do a either a adjustable track bar or a track bar lowering/raising bracket or both.
Maybe someone else can explain a bit more geometrically.
Mon May 08, 2017 10:16 am
Yes, with a lift the axle will swing to the driver's side. If you have not extended your bump stops, you should leave the track bar alone. It is important that the suspension hits the bumpstops squarely at full compression. Changing track bar length will alter where the bump stops impact the frame.
Ideally you should install a track bar riser on the axle and adjust bump stop height as needed. However a track bar riser or drop bracket will alter steering geometry too, so be prepared to deal with that.
Mon May 08, 2017 10:22 am
Mon May 08, 2017 11:15 am
Try turning your Bumper right side up... Maybe that will help the geometry!??? :laughing2:
Just Kidding, I flunked Geometry and had the same thing happen on my 3.5" lift!!!
Mon May 08, 2017 11:55 am
Mon May 08, 2017 12:48 pm
Mon May 08, 2017 1:26 pm
Mon May 08, 2017 1:29 pm
Mon May 08, 2017 9:51 pm
Users browsing this forum: No registered users and 55 guests
32,958,292 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
