www.ColoradoClassicBroncos.com - View topic - ZF 5 speed
It is currently Sun Nov 24, 2024 7:31 pm
Reply to topic  [ 11 posts ]
 ZF 5 speed
Post ZF 5 speed
So just taking an opinion pole. So for those of you that have the ZF do you think it was worth changing out your C4 or NP 435. Tell me what you think & what engine you are running.
Sun Jul 23, 2017 12:35 pm
Profile WWW
Post Re: ZF 5 speed
Haven't done it yet, but have a ZF on my garage floor waiting to replace my NP435. Looking forward to having an overdrive gear.
Sun Jul 23, 2017 5:41 pm
Post Re: ZF 5 speed
What Justin said. Not sure if it's truly worth it yet but I came by the transmission pretty cheap.
Sun Jul 23, 2017 6:44 pm
Post Re: ZF 5 speed
Absolutely worth it!
Switched from NP435 to ZF5 behind a 351W.
I can comfortably cruise at 75 MPH @2500 rpm and the 351 can still pull the hills without a problem. Additionally, the hydraulic clutch is more reliable than the old link setup.
Sun Jul 23, 2017 10:21 pm
Post Re: ZF 5 speed
That's what I was wondering. How much did your low range rock crawling change?
Mon Jul 24, 2017 9:08 am
Profile WWW
Post Re: ZF 5 speed
Forgot what tire size & gear ratio are running?
Mon Jul 24, 2017 9:09 am
Profile WWW
Post Re: ZF 5 speed
I had an NP435 in my old bronco with the original and VERY tired 302. I had 3.50's and 33's at the time. The NP435 was the only way I could crawl at a reasonable cost. That bronco is gone, but new one has a ZF5, 4.10's and 35's with a 351 EFI. As Digger said, it will cruise on the Interstate pretty easily. Mine is more of a trail rig and not so comfortable on the road, but...on smoother roads I have looked down to find myself going 70 without noticing.
IMO - the ZF5 is the best way to go for us who prefer the manual tranny! It offers a decent granny gear, and a great OD. If you need deep crawling gears, the best place for those is in the T-case. The axle ratios should match your highway cruising/tire size selection.
Just make sure you buy a quality master cylinder, not a chain parts store version. Perhaps a tranny rebuild shop is the best source.
Mon Jul 24, 2017 10:30 am
Post Re: ZF 5 speed
Mon Jul 24, 2017 1:45 pm
Post Re: ZF 5 speed
Thanks guys that's the info I was hoping for some real world experience.
Mon Jul 24, 2017 2:10 pm
Profile WWW
Post Re: ZF 5 speed
Had a np435 switched to zf. Was definitely worth all the trouble I went through. Low range differences are hardly noticeable.
Mon Jul 24, 2017 4:35 pm
Post Re: ZF 5 speed
I really like the ZF-5 in my Bronco, it is much better than the C-4 that I had. My set up is 37's, 4.88 gears, 3.8:1 Atlas, and a 302. I can cruise 70-75 mph on the highway with no problems and then put it in low range and crawl. On my trip to Moab mostly used 2nd to crawl, 1st can crawl up about anything but doesn't have enough wheel speed when you need it.
Mon Jul 24, 2017 5:06 pm
Users browsing this forum: No registered users and 63 guests
33,011,950 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
