www.ColoradoClassicBroncos.com - View topic - 1975 OEM Bronco Parts
It is currently Fri Nov 22, 2024 3:43 am
Reply to topic  [ 20 posts ]
Post 1975 OEM Bronco Parts
I have some parts for sale that I will not be using on my 1975 build. Here is the first round of parts I have before posting to CL.
Thanks,
Steve
Both Front Seats 50.00 SOLD!
Tire Carrier w/hardware 60.00 SOLD!
Transfer case skid plate 10.00
Rear gas tank skid plate 10.00
saddle tanks w/hardware 25.00 SOLD!
Rear gas tank NOT OEM 25.00
2-side mirrors 25.00 SOLD!
OEM air cleaner 40.00
2-barrel carb D60E-BA needs rebuilt 50.00
Mon Jul 24, 2017 9:23 am
Post Re: 1975 OEM Bronco Parts
seats and tire rack please!
where are you located?
Mon Jul 24, 2017 9:33 am
Frederick Firestone , but work in Broomfield area around Wads and HWY 36.
Mon Jul 24, 2017 9:56 am
I'm up North of Greeley so Firestone area works
Mon Jul 24, 2017 10:17 am
PM Sent
Mon Jul 24, 2017 10:21 am
Steve, i will take your mirrors. Dave j
Thu Jul 27, 2017 10:38 pm
Hey Dave,
CravenBronco sent me a PM yesterday at 8pm for measurements on the mirrors, as soon as I hear back from him I'll let you know if they are still available. Last time we spoke you said you might be interested in the bumpers and will give you first shot at them, I will text you picks this weekend.
Fri Jul 28, 2017 6:52 am
No problem. Let me know.
Fri Jul 28, 2017 5:48 pm
Adding the OEM 44/9" axles both are drum brakes and complete it looks like the 9 is the small bearing, according to the Marti Report it has 4:11 gears. The manually lock outs are not the Ford red one. SOLD!!
Thanks Steve
Tue Aug 01, 2017 9:08 am
According to my records WEM-A3 is HD large bearing. It is if it has 11" drums.
Tue Aug 01, 2017 10:50 am
Interesting? I believe the front drum is stamped 11" I just took a quick caliper reading this morning and compared my 76-F150 9" and it was about a 1/4" smaller, I will double check the rear drums this evening.
Thanks for the info Viperwolf1
Tue Aug 01, 2017 2:18 pm
It will have the maximum size cast into the outside of the drum. Something like 11.090".
Tue Aug 01, 2017 6:19 pm
I just removed/cleaned up the 3-speed transmission out of the 75 bronco if anyone is interested in it.
* 1975 3 speed transmission $75.00. SOLD!!
* 1975 Radius Arms $40.00
* 1975 3-speed transmission bell housing $20.00
* 1975 3-speed misc linkage ?
Thu Aug 10, 2017 1:20 pm
HI: I'm interested in one saddle tank. How much and does it come with sending unit etc. Any leaks /. DanO
Thu Aug 10, 2017 8:37 pm
Hey Dan,
The side saddle tank is complete with sending unit all the brackets/skid plate no leaks, I dropped the tank and flushed and cleaned prior to firing up the motor. $ 25.00 for everything.
Fri Aug 11, 2017 6:36 am
HI: I would like to take it off your hands. Will you be at the upcoming breakfast in Longmont.
Fri Aug 11, 2017 7:51 am
HI: I would also like to buy your stock air cleaner if still have it. Dan
Fri Aug 11, 2017 8:14 am
Hey Dan,
I might be relocating my Daughter to WA that week, I'm located in Frederick and about 15 minutes south/east from Roosters. Ill sent you a PM with my phone number/address.
Yes I have the air cleaner as well.
Fri Aug 11, 2017 8:21 am
HI: I may have to recline the air cleaner. I have a 4 barrel and believe the OEM air cleaner is for a two barrel Carb. Is this correct. I defiantly want the Aux tank. Dan
Fri Aug 11, 2017 7:18 pm
Thu Aug 24, 2017 9:51 pm
Users browsing this forum: No registered users and 33 guests
32,941,280 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
