Register •
FAQ
• Login
It is currently Sun Nov 24, 2024 6:25 pm
[ 5 posts ] |
BOBS 2 68S
Huston we have a problem
I was elk hunting earlier this week. We felt and heard a bang, thought I hit a rock with the rear diff. Found this broken rear shock the next day. I thought it had more bounce in the rear. But the 1/2 cab has a bounce. It was time time to replace the 20 year old shocks. It looks like the shock unscrewed it self. Tried to get it apart at camp but the nut was too rusted even using the jack it would not turn. Power tool and heat nothing. won with cutoff wheel. The 1/2 inch bolt was a grade 8, one on the front was also an grade 8. So shock mounting bolts grade 5 or grade 8?
Fri Sep 15, 2017 4:53 am |
Re: Huston we have a problem
Most factory automotive hardware is grade 5 and it's more than enough for a shock mount.
Fri Sep 15, 2017 5:41 am |
I'll bet with quality shocks, the bounce goes away! Might I suggest Bilstein?
Fri Sep 15, 2017 3:31 pm |
BOBS 2 68S
Want Bilstens but can afford WH store brand. Bronco money went to new radiator 3 weeks ago.
Sat Sep 16, 2017 4:10 am |
Buy used 7100s and rebuild them. Or don't, used in that category is usually great.
Sat Sep 16, 2017 6:34 pm |
[ 5 posts ] |
Users browsing this forum: No registered users and 16 guests |
