It is currently Thu Nov 21, 2024 10:46 am
Re: TJ's 74 Bronco money pit
They could have tested it with an electric fan operating so there would be a load from alternator
Thu May 04, 2017 5:39 pm |
cpldavis37
Progress!
Wed May 17, 2017 12:53 pm |
cpldavis37
Engine installed, Dash restored, glove box built and a few other small things. I am getting close on this one.
Mon Oct 16, 2017 6:10 pm |
cpldavis37
Half of my order. More to come.
Sat Oct 21, 2017 3:10 pm |
The engine looks great !
Have you dry fit enough upper intake to see if those valve cover studs will clear ?
Sat Oct 21, 2017 3:25 pm |
cpldavis37
I bought different fasteners for the valve covers I didn't like those ones.
Sat Oct 21, 2017 4:28 pm |
Wow, are you planning on paint as well?
Sat Oct 21, 2017 6:01 pm |
cpldavis37
Yes, but it will run first, I hope.
Sat Oct 21, 2017 6:40 pm |
cpldavis37
Had to build a bench in preparation for the Bronco push. Then I got a new tool box to go with the bench.
Sun Oct 22, 2017 6:48 pm |
There is something to be said for organized tools! Jobs go much quicker that way!
Mon Oct 23, 2017 8:24 am |
Nice bench.
I see you rely on the Rox Crusher gravity method of vise attachment.
Mon Oct 23, 2017 9:28 am |
cpldavis37
Mon Oct 23, 2017 11:00 am |
Mon Oct 23, 2017 2:17 pm |
Guilty here as well!
Mon Oct 23, 2017 2:47 pm |
cpldavis37
More work. It's getting close.
Wed Oct 25, 2017 8:10 pm |
Very clean!! Nice work. Even the lighter holder looks clean!
Wed Oct 25, 2017 8:46 pm |
That looks great in there!! How close to the header is your plug wires on the drivers side? Looks close, but they probably aren't.
Wed Oct 25, 2017 8:49 pm |
cpldavis37
It's not bad. I can make adjustments later. 96 wires are really long so I can route them anyway I want.
Wed Oct 25, 2017 9:29 pm |
Strike2
That looks great! nice work, is all the front dressing off a 96 explorer?
Thu Oct 26, 2017 7:17 am |
cpldavis37
The serpentine setup comes from a 98 with the exception of the AC delete pulley. That came from my old Mustang setup. I don't really need it, I just thought it looked better with it. The wires are from 96. A 98 has "gt40p" heads and I believe they have some odd bends in them. A 96 has 90* bends at the plug and are better suited for my application and headers.
Thu Oct 26, 2017 12:02 pm |
cpldavis37
New toys!
Fri Nov 03, 2017 8:53 pm |
Strike2
Those are parts, interested to see how the sliders install/look as I’m getting ready to see about adding some to my build.
Sun Nov 05, 2017 8:40 am |
cpldavis37
I was going to mock up the cage and got carried away and it's 75% welded. I love it!
Thu Nov 09, 2017 4:20 pm |
Strike2
That cage looks great! On the B pillar are those attachment for seat belts?
Thu Nov 09, 2017 7:19 pm |
cpldavis37
Yes
Thu Nov 09, 2017 7:50 pm |
cpldavis37
Here is an update. Here we go, Roll Cage welded and bed lined, POR 15 the under side, bed lined the wheel wells, Wiring 90% done, EFI harness and computer done, Explorer 4.0 Radiator and Taurus fan installed and wired, Aux Land Rover pusher fan installed and wired, Dash assembled and installed, new heater core and all new lines. I am leaving some stuff out, but needless to say I have made a ton of progress. My new steering column will be here Saturday and the 23 gal tank should be in before the new year. I might hit my deadline of starting on January 1st.
Thu Dec 14, 2017 10:46 pm |
cpldavis37
More.
Thu Dec 14, 2017 10:48 pm |
cpldavis37
More.
Thu Dec 14, 2017 10:54 pm |
Nice work!
20mm ammo can for a center console?
Thu Dec 14, 2017 10:59 pm |
cpldavis37
Yes sir.
Thu Dec 14, 2017 11:19 pm |
