www.ColoradoClassicBroncos.com - View topic - Pitman Arm options
It is currently Fri Nov 22, 2024 5:48 pm
Reply to topic  [ 8 posts ]
 Pitman Arm options
Post Pitman Arm options
I am looking at options to swap out a pitman arm on my 4x4x2 box to gain a little distance from the drag link and lower link at compression. - I don't know what or if I have options but would love to find a drag link that is slightly shorter, even 1/4 or less. I can take some measurements tonight if need be. Thanks!
Mon Oct 30, 2017 9:23 am
Post Re: Pitman Arm options
Pictures would be helpful. So you say there is a potential interference between the pitman arm and the Tie-rod at compression? Can you clock your pitman arm to help?
Mon Oct 30, 2017 10:49 am
Mon Oct 30, 2017 11:17 am
I was just thinking if you could clock it one tooth, that may be just enough to gain the clearance you need. But I do think that some of them you cannot clock because they have alignment splines. However, it is all in how the wheels are turned. A turn in any direction will help open up that gap.
How much of an interference is it? Just a scrape? I wouldn't worry about it. Even if it's a hard rub, I wouldn't be concerned. If it's trying to bend one or the other, then you could grind flat spots at those sections and repaint. I doubt you'd grind away enough to worry about strength issues.
Perhaps there is a slightly shorter pitman arm out there as well? Is that a drop arm? Maybe a flat one would be better?
Do you think at full compression that the tie-rod DOM will hit the joint at the pitman arm?
Mon Oct 30, 2017 11:57 am
Mon Oct 30, 2017 1:02 pm
The manual steering arms are slightly shorter but also less beefy.
Tue Oct 31, 2017 7:36 am
Tue Oct 31, 2017 9:20 am
Astro arms are also short and completely flat.
Tue Oct 31, 2017 10:20 am
Users browsing this forum: No registered users and 28 guests
32,954,720 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
