www.ColoradoClassicBroncos.com - View topic - Engine Gurus...289 Rebuild or Replace???
It is currently Fri Nov 22, 2024 5:19 pm
Reply to topic  [ 25 posts ]
Post Engine Gurus...289 Rebuild or Replace???
I finally got the engine, a 289, running in my ‘68, “runs & sounds” great, smooth. Has four barrel carburetor. BUT!!! It smokes horrendously from the tailpipe and overheats just idling in the driveway and there’s almost no oil left on the dipstick from my original oil change. I’ve put 0 miles on the engine since I bought the Bronco - I’m guessing it’s the original engine no rebuild.
From what little engine knowledge I have, sounds like it needs a lower end rebuilt, ring job? ( I really have no idea or engine experience)
I’m wondering if I should have the entire engine rebuilt or if I can just have the lower end rebuild or whether I should try to find a good running used 289 or 302 and just replace it with that?
I’m looking for the best bang for the buck, and I certainly don’t want to buy a $300 engine, install it and find out it needs the same or more work than my old one. Any thoughts, ideas welcome!
Thanks
Sun Nov 05, 2017 1:03 pm
Post Re: Engine Gurus...289 Rebuild or Replace???
Pull it all and have it all gone through. Including having the heads checked as well as a valve job. Go talk to the guys at greeley automotive and machine.
Sun Nov 05, 2017 4:40 pm
^ what he said.
Sun Nov 05, 2017 6:44 pm
x3. I've been impressed with Western Engine Supply. The did the heads on the engine I built and it was quality work.
Sun Nov 05, 2017 8:46 pm
Yep what ^^^^^ they said
Mon Nov 06, 2017 5:27 am
Rebuild it
Mon Nov 06, 2017 7:39 am
Are you concerned with originality? Perhaps there are gains to be had with rebuilding a used 302 instead? 351?
In any case, it's unanimous - rebuild it!
Mon Nov 06, 2017 10:13 am
Mon Nov 06, 2017 10:53 am
Ok, so rebuild it. Yeah I figured as much. I just called and talked to Greeley automotive and machine(gamracingengines.com)
Nice guy, very informative as to what probably needs to be done and as far as $$$ goes, he said plan on $2500-$3000. He said that's pretty standard for a stock kind of rebuild.
I'm sure that's a bargain, but not what I bargained for. Looks like I'll be doing a cheap used engine swap. Maybe I can find one fresh out of a Mustang or Bronco that I can see running before its pulled?
I just can't swing that kinda cheese :(:(:(
Thanks for your input!
Mon Nov 06, 2017 10:55 am
Yikes, that’s approaching crate engine prices. Do yourself a favor and get a quote for just the machine work and replacement parts without assembly, it should be less than 2k.
Mon Nov 06, 2017 12:23 pm
Good used engines are out there. I sold my 302 long block in good shape for something like $300.
Mon Nov 06, 2017 2:00 pm
I might have a good 302 long block this winter if I decide to do the roller 5.0 this winter.
Mon Nov 06, 2017 2:04 pm
Mon Nov 06, 2017 2:49 pm
Mon Nov 06, 2017 3:44 pm
Thanks Rob,
I’ll give him a call tomorrow.
Mon Nov 06, 2017 9:11 pm
I have some awesome engine rebuilding videos that were priceless when I built my 427. Those coupled with some good YouTube videos and you're on your way to rebuilding it yourself. Happy to loan out.
Tue Nov 07, 2017 7:44 am
Thanks guys, I appreciate the encouragement!
I'll post up when I figure this out... banghead
Tue Nov 07, 2017 10:49 am
I have a bunch of new top end stuff if needed. Cam, lifters, rockers, timing chain, etc
Tue Nov 07, 2017 3:28 pm
Ok, well it must have been fate? I got a running 289 heart transplant out of a '65 mustang fastback that I got to see run...and do burnouts!!! The owner said the engine in the Mustang was originally out of an early Bronco!!!
Sounded healthy but just the fact that I saw it run was enough for me! And at $200 bucks I won't complain! (yet ;)
to be continued...
Mon Nov 13, 2017 12:46 pm
Full circle, both the engine and donuts!!! No video of said burnouts?
Mon Nov 13, 2017 12:49 pm
Mon Nov 13, 2017 12:57 pm
Mon Nov 13, 2017 1:31 pm
Mon Nov 13, 2017 1:40 pm
Congrats on finding a motor! You know your now committed to post a Bronco burnout icon biggin
Mon Nov 13, 2017 2:49 pm
Mon Nov 13, 2017 3:57 pm
Users browsing this forum: Google [Bot] and 24 guests
32,954,217 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
