[phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4794: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4796: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4797: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4798: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) www.ColoradoClassicBroncos.com - View topic - Explorer 5.0 maf sensor?
any body know if the transfer table on the explorer 97 maf would work with the various maf ecms we use on these swaps? I have an explorer 5.0 with rjm harness and keep getting lean codes.trying to pin point the issue. Would I be better off to get a maf and housing from say a 94-95 mustang? I am currently using the explorer maf and housing with a flange adapter and cone air filter, (going to try to adapt the explorer air box at some point), and a square to oval adapter for the harness to the sensor. Any knowedge outs greatly appreciated.
Mon Nov 20, 2017 11:24 am
EFI Guy
Re: Explorer 5.0 maf sensor?
The transfers are quite different. The 94-95 is very close down low but peels away about halfway through the voltage range....I do know a guy that can program for that 97 MAF. =)
