www.ColoradoClassicBroncos.com - View topic - Various free parts for local pick-up
It is currently Wed Nov 27, 2024 3:42 am
Reply to topic  [ 13 posts ]
Post Various free parts for local pick-up
I have a number of things that I will throw out as free or beer donation accepted.
- upper floor section from passenger side
- ignition module
- 2" aluminum 2 barrel carb spacer
- wiper arms and blades
- Fan blade and fan bracket
- shifter collar and shifter
- I think a couple of throttle linkages
- various v-belt brackets
- harmonic balancer 28oz.
- wiper fluid container and motor (works)
- hubs from my D30 (Phil- let me know if you want these)
- 4* c bushings - in good shape
- v belt pulleys
- mechanical fuel pump - barely used.
- steering column to dash cover - no cracks
- 351 timing chain cover
- air breather and filters
Mon Nov 20, 2017 2:43 pm
Post Re: Various free parts for local pick-up
Lower steering shaft from 73 auto column with stock power steering. Rag joint and upper rag joint connection included.
Drive shaft-- has the old borg warner yoke in case you need one as a spare.
Mon Nov 20, 2017 2:53 pm
I would be interested in the floor section.
Mon Nov 20, 2017 2:56 pm
PS Pump & brackets!
Please!
Mon Nov 20, 2017 3:12 pm
I will take the hubs, it will help with what I am doing.
Mon Nov 20, 2017 3:13 pm
windshield wiper reservoir also please!
Mon Nov 20, 2017 3:14 pm
Jason- floor piece is yours
Phil- hubs are yours (I also found some drums if you want them-- let me know so I can pull them from the dump truck)
Mike-- got yours set aside
Mon Nov 20, 2017 5:12 pm
Mon Nov 20, 2017 10:33 pm
If still available, i will snag your fuel pump, fan blade and blade mount. Thanks, dave
Tue Nov 21, 2017 1:29 am
If the steering shaft & driveshaft are in usable condition I’d like them.
Tue Nov 21, 2017 5:35 am
Tue Nov 21, 2017 9:54 am
Interested in the shift collar and shifter, and wiper arms and blades.
Also interested in throttle linkages, if you have them.
Thanks
Sat Nov 25, 2017 3:17 pm
Sat Nov 25, 2017 4:26 pm
33,167,544 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
