It is currently Wed Nov 27, 2024 3:53 am
[ 13 posts ] |
Various free parts for local pick-up
I have a number of things that I will throw out as free or beer donation accepted.
- upper floor section from passenger side - ignition module - 2" aluminum 2 barrel carb spacer - wiper arms and blades - Fan blade and fan bracket - shifter collar and shifter - I think a couple of throttle linkages - various v-belt brackets - harmonic balancer 28oz. - wiper fluid container and motor (works) - hubs from my D30 (Phil- let me know if you want these) - 4* c bushings - in good shape - v belt pulleys - mechanical fuel pump - barely used. - steering column to dash cover - no cracks - 351 timing chain cover - air breather and filters
Mon Nov 20, 2017 2:43 pm |
Re: Various free parts for local pick-up
Lower steering shaft from 73 auto column with stock power steering. Rag joint and upper rag joint connection included.
Drive shaft-- has the old borg warner yoke in case you need one as a spare.
Mon Nov 20, 2017 2:53 pm |
TOOLMAN
I would be interested in the floor section.
Mon Nov 20, 2017 2:56 pm |
PS Pump & brackets! Please!
Mon Nov 20, 2017 3:12 pm |
pgilbeau
I will take the hubs, it will help with what I am doing.
Mon Nov 20, 2017 3:13 pm |
windshield wiper reservoir also please!
Mon Nov 20, 2017 3:14 pm |
Jason- floor piece is yours
Phil- hubs are yours (I also found some drums if you want them-- let me know so I can pull them from the dump truck)
Mike-- got yours set aside
Mon Nov 20, 2017 5:12 pm |
pgilbeau
Mon Nov 20, 2017 10:33 pm |
cdj7k
Joined: Fri Oct 04, 2013 12:08 pm Posts: 32 Images: 0 Location: Colorado springs
If still available, i will snag your fuel pump, fan blade and blade mount. Thanks, dave
Tue Nov 21, 2017 1:29 am |
If the steering shaft & driveshaft are in usable condition I’d like them.
Tue Nov 21, 2017 5:35 am |
Tue Nov 21, 2017 9:54 am |
JimGL
Joined: Mon Nov 21, 2011 8:48 pm Posts: 22 Location: Golden, CO
Interested in the shift collar and shifter, and wiper arms and blades. Also interested in throttle linkages, if you have them. Thanks
Sat Nov 25, 2017 3:17 pm |
Sat Nov 25, 2017 4:26 pm |
[ 13 posts ] |
