www.ColoradoClassicBroncos.com - View topic - Removing lower steering shaft
It is currently Fri Nov 22, 2024 5:40 pm
Reply to topic  [ 25 posts ]
Post Removing lower steering shaft
Does anyone here have the magic instructions on how to remove the lower steering shaft on a '74. I've taken all the bolts off the rag joint and the bolt on the lower u-joint that connects to the gearbox, but it's going no where!
Go Hard or Go Home
Tue Dec 19, 2017 2:57 pm
Post Re: Removing lower steering shaft
Garsh Darn Chevy Parts!!!!!
Tue Dec 19, 2017 3:29 pm
You should be able to pull up to clear the rag joint end and then try to pry open the area a little bit that the lower bolt was clamping down. After that, try to either pull and hit the lower section with a dead blow or take a skinny pry bar and start to work the lower section out off the threads.
Tue Dec 19, 2017 4:31 pm
I ended up unbolting the gearbox and it gave me enough room to slip the shaft off. Those studs on the rag joint are too long to let it just slip by, and they don't come out. Stupid design! Now I need to get the upper rag joint off the shaft -- but that's gonna wait until tomorrow!
Go Hard or Go Home
Tue Dec 19, 2017 5:30 pm
If you're going to put a collapsible lower shaft in you need to remove the flange on the upper shaft. It is splined to the upper shaft and is also peened on the end. It's going to be difficult to remove. Might have to grind the peened end of the flange to get it to the point where it can removed with a puller. Try not to damage the splines because you'll need those for the new u-joint.
Tue Dec 19, 2017 6:12 pm
Go Hard or Go Home
Tue Dec 19, 2017 8:04 pm
I had to pull my column and cut the mount off. Didnt cut all the way through but got it close and just smacked it with a punch.
Tue Dec 19, 2017 8:06 pm
Well, I tried soaking in penetrating oil over night and then put a puller on it and tapped with a hammer. It's ON there! I guess I'm waiting for reinforcements to arrive for this project. I'm not going to drop the column without some help (and someone that knows that they're doing). This is been one of the most frustrating projects I've done on these stupid old trucks! bangtard
Go Hard or Go Home
Wed Dec 20, 2017 2:03 pm
I can give you a hand, text me and we’ll set up a time.
Wed Dec 20, 2017 4:00 pm
Go Hard or Go Home
Wed Dec 20, 2017 5:23 pm
Well, this sob isn’t going down without a fight - but I’ve got it on the run. 5 dremel cutting blades later... off to HD for more blades because it won’t budge from here. Image
Go Hard or Go Home
Thu Dec 21, 2017 10:37 am
You may consider throwing a torch at it to heat it up and then tap on that right side to see if it’ll separate itself.
Thu Dec 21, 2017 10:42 am
I also had to cut that bevel off the shaft to fit the new lower on it.
Thu Dec 21, 2017 10:59 am
Go Hard or Go Home
Thu Dec 21, 2017 11:06 am
Go Hard or Go Home
Thu Dec 21, 2017 11:07 am
From the looks of it the splines are still mushroomed out on the end, you’re going to need to trim a little off.
Thu Dec 21, 2017 12:35 pm
I used a TBP lower shaft and it had some very good instructions on how to do this. Did yours not come with any?
Thu Dec 21, 2017 1:00 pm
Go Hard or Go Home
Thu Dec 21, 2017 4:44 pm
My old boss was taught in the navy to soak it in coke-a-cola
then some rum
and a bronco with a warm fuzzy feeling
Fri Dec 22, 2017 5:55 am
Victory! I did get a little too deep on one cut, but it doesn’t look like the spline is really hurt. New shaft should arrive today, and hopefully the instructions will tell me how to deal with the end of the shaft. My wife made me promise to stay out of the shop while the family is in town, but what I do when everyone is still in bed shouldn’t count, right? Image
Go Hard or Go Home
Fri Dec 22, 2017 9:52 am
ImageImage Family left, so I’m allowed back in the shop.
New gearbox and steering shaft in place! Thanks for the tips and encouragement! This job really isn’t possible without a good dremel!
Go Hard or Go Home
Sat Dec 30, 2017 11:22 am
Looks really nice!! You should notice a firmer steering!
Mon Jan 01, 2018 5:23 pm
I put a tack weld on each side of the joint. Easy to remove, and those set screws made me a little nervous. I've heard horror stories about them coming loose.
Sun Jan 07, 2018 7:53 pm
Go Hard or Go Home
Sun Jan 07, 2018 8:01 pm
x2 I had my lower shaft come off the steering box. Luckily I was only going maybe 25 mph and a rock pile and wooden fence broke my fall. Scary stuff when you realize your wheel is still spinning but no turning is happening
Thu Feb 22, 2018 9:42 am
Users browsing this forum: No registered users and 26 guests
32,954,584 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
