It is currently Fri Nov 22, 2024 4:04 pm
[ 12 posts ] |
B.O.B.
Heater upgrade
Got the new motor and cage for the upgrade but can't get the heater to operate. The motor s end like it is grounded by the housing. I have a ground wire coming off but it still won't work. Did I get the right motor or am I just not grounding it right?
Sun Mar 26, 2017 10:57 am |
Re: Heater upgrade
I'd bench test the motor, I guess. Sounds right to me. I used the parts listed in this thread (maybe a different brand, but crossreferenced to the same vehicle, I forget), and added a ground wire from the motor to the metal part of the heater housing. Seemed to ground fine with the heater housing bolted to the firewall. http://www.classicbroncos.com/forums/sh ... ostcount=6
Sun Mar 26, 2017 11:18 am |
D&D72
Re: Heater upgrade
X2 I made a ground the same way. works good!
Sun Mar 26, 2017 1:40 pm |
B.O.B.
Re: Heater upgrade
Bench tested and works well. When installed in truck it pops the fuse because it doesn't seem like it's ground d well enough . Any thoughts.
Sun Apr 30, 2017 6:34 pm |
horseplay
Re: Heater upgrade
A popping fuse will be a power short to ground or circuit overload. Check your wiring and make sure your cage is free inside the boxö
Sun Apr 30, 2017 7:56 pm |
Re: Heater upgrade
Mon May 01, 2017 11:53 am |
Re: Heater upgrade
My heater fuse (in the original fuse box) was actually melting the solder inside the fuse itself. The tabs that held the fuse in place were rusty, and I cleaned them up with some sand paper & everything started working fine again.
Do you have a similar sized fuse on the bench test? That would eliminate the fan itself as the problem.
Mon May 01, 2017 12:18 pm |
B.O.B.
Re: Heater upgrade
So the cage was hitting the metal housing on the back and grounding out. Has anyone had to make a spacer plate between the motor and th housing. I cross referenced all the parts and they seem correct. What do you all think?
Wed Dec 06, 2017 9:28 pm |
Re: Heater upgrade
It's been a long time since I did this but I seem to remember that the fan had to be clocked to a specific location, or there was a problem. This might not be the same thing you have happening. It's just been to long ago for me to remember the specifics.
Wed Dec 06, 2017 9:59 pm |
Re: Heater upgrade
I also remember that I had to clock or move the motor slightly in the housing. I will be doing this on the 72 here soon so will refresh my memory.
Thu Dec 07, 2017 8:38 am |
B.O.B.
Re: Heater upgrade
Had a buddy with a 3d printer make a small spacer between the housing and the motor to clearance the cage. Should work like a charm now. Got my reseal kit for Christmas so just need to do that and should be golden.
The core seems good but do you all think I should replace?
Mon Jan 01, 2018 9:31 pm |
Re: Heater upgrade
Tue Jan 02, 2018 5:24 pm |
[ 12 posts ] |
