www.ColoradoClassicBroncos.com - View topic - PS Low Pressure Fitting
It is currently Fri Nov 22, 2024 4:09 pm
Reply to topic  [ 26 posts ]
Post PS Low Pressure Fitting
I installed a dual return PS pump, and the bend in the low pressure fitting on the gear box is too severe now. I'm sure I can cut off the line with a tubing cutter, but would prefer to get a new line so I've got some sort of "barb" on the end to keep the 3/8" id hose from slipping off. Does anyone know where I can get a new line made locally?
Go Hard or Go Home
Sun Feb 11, 2018 3:23 pm
Post Re: PS Low Pressure Fitting
Parker Hose in Denver will make one up while you wait.
https://www.google.com/maps/place/Parke ... 04.9052702
Sun Feb 11, 2018 3:30 pm
Thanks -- I'll swing by there next week
Go Hard or Go Home
Sun Feb 11, 2018 4:14 pm
I believe the NAPA Auto Parts in Parker will also make up hydraulic lines.
Go Hard or Go Home
Sun Feb 11, 2018 4:23 pm
Next to Walgreens at the SW corner of Lincoln and Parker Road.
:burnout:
Sun Feb 11, 2018 5:48 pm
Can they build in a 45* like the other fitting? Perhaps that would avoid a future issue?
Mon Feb 12, 2018 9:18 am
Go Hard or Go Home
Mon Feb 12, 2018 9:24 am
Napa guys looked at me with crossed eyes and tried to point me to a bearing place downtown Denver. Off to Parker Hose on 46th
Go Hard or Go Home
Mon Feb 12, 2018 11:25 am
Well, the Parker hose guys couldn’t make the piece like I wanted because their tooling is too big - but - they pieced together some parts that got me what I needed. This was a great find because they can make up custom hydraulic lines (including SS) and they were super helpful. I’ll be back in biz soon. Just in time for a ball joint replacement later this week!
Go Hard or Go Home
Mon Feb 12, 2018 12:07 pm
One step at a time...
Mon Feb 12, 2018 1:22 pm
Mon Feb 12, 2018 4:25 pm
FYI they probably told you to go to Whistler bearing which has a hydraulic hose division also, it rivals the Parker store. To my knowledge they are the only place in town that can custom make DOT approved brake hoses on the spot. Have used them many times along with hydraquip (formerly emrich & Hill) & the Parker store.
Sent from my XT1254 using Tapatalk
Mon Feb 12, 2018 10:51 pm
Profile WWW
Go Hard or Go Home
Mon Feb 12, 2018 10:56 pm
Hydraulic lines used to scare me....it was one of those things I had never attempted before.
It's not a big deal. Order hose and fittiings from Summit (a few bandaids from Walgreens if you're doing braided stainless), and you're good to go. Way cheap and you can make perfect custom lengths with whatever fittings you need.
Tue Feb 13, 2018 8:30 am
Go Hard or Go Home
Tue Feb 13, 2018 8:42 am
Tue Feb 13, 2018 8:53 am
Hey Scott,
If you need I think i have an extra AN adapter for the steering box if you need. I am almost ready to make new lines for mine also a dual line power steering pump and i have a spare that i am bring to baja.
Let me know if need.
Mike
Tue Feb 13, 2018 11:45 am
Wed Feb 14, 2018 10:17 am
I'm with Airbur. I did all the lines on my power steering, hydroboost and suspension. Blew one the moment I pressurized it on the first one I did, but no issues since. It made a spectacular mess.
Sun Feb 18, 2018 12:10 pm
Go Hard or Go Home
Sun Feb 18, 2018 12:39 pm
The cooler is likely AN fitting, maybe a somewhere between a a -3 and -5? The steel fitting in your hand is probably a inverted flare, same used in brake systems. Ironically, I think the thread size/pitch is the same you would find on a bolt. 1/2"-20 or maybe larger? Take that fitting to the hardware store and start trying to thread nuts onto it.
Speedwaymotors.com might be a good source for your AN fittings, then you can do like airbur did.
Sun Feb 18, 2018 4:53 pm
Best local source for AN fittings is Emrich & Hill in Denver, it actually has a new name that I’ll try to remember. SS tubing is harder than mild steel tubing, not sure if a regular tool will hold up.
Sun Feb 18, 2018 5:28 pm
Go Hard or Go Home
Mon Feb 19, 2018 8:47 am
Scott,
I think this is the part number
AEROQUIP FBM2964 AN-6 ADAPTER
o 3/8 Male Inverted Flare to AN-6 Male Adapter
o S.A.E. 37 / 45 Flare (JIC/AN) 5/8-18 thread
o For use with Aeroquip TFE AN-6 Spec Hose
o Silver Zinc Dichromate Finish Mild Steel
o Fits most 1979 and older Saginaw P Series Pumps with
3/8 flare female output / Saginaw Box Low Pressure Return
This is from the Hydratech
I think i have an extra one i can look tonight if you need it?
You can also get them at summit, jegs or amazon.
Mike
Mon Feb 19, 2018 12:39 pm
Go Hard or Go Home
Mon Feb 19, 2018 1:54 pm
32,953,162 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
