It is currently Sun Nov 24, 2024 4:55 pm
[ 22 posts ] |
Saggy stance
Installed a WH 3.5” suspension years ago, probably 2010. WH front springs are known to settle a fair bit during first year, which mine did, so I installed 4.5” springs up front.
Now, a couple years later, the rear seems to be settling / sagging and I️ don’t like the stance.
ANy input on what to expect if I were to get new 3.5” springs ?
Sun Dec 31, 2017 5:03 pm |
Dirtheadz
Re: Saggy stance
I'm a fan of Prerunner sag (ofcaorse I'm odd X desert guy). Could always do a thin add-a-leaf... just a thought
Sun Dec 31, 2017 6:12 pm |
Re: Saggy stance
Add more weight to the front. Mine has finally settled out after sitting nose low for years.
Sun Dec 31, 2017 6:34 pm |
horseplay
Re: Saggy stance
you could have your springs re-arched @ Denver spring.
Sun Dec 31, 2017 11:31 pm |
BroncoCrawler
Re: Saggy stance
To be honest I would not have your springs re-arched. I worked at Denver spring for a year and saw the process they use. The re-arch rarley lasts especially if your gonna wheel it and stress the springs. They will probably offer to add a leaf also but it most likely will be one big thick leaf and ride rougher and hurt articulation.
When I redid my springs two years ago. I ordered 2" fronts and 3.5" rears...... Now with all my tools. New rear bumper, high lift, spare, full 24gal fuel I sag a 1/2". Wish I would of bought 4.5" rears. These are deavers from Jeff's.
Sent from my XT1254 using Tapatalk
Mon Jan 01, 2018 10:10 am |
horseplay
Re: Saggy stance
good to know that it seems to be a short term solution.
Mon Jan 01, 2018 11:13 am |
Re: Saggy stance
Mine did that as well. I ended up ordering a new set of 11-leafs from Tom's. Now it's level. I think wheeling is just hard on them all.
Mon Jan 01, 2018 5:21 pm |
Re: Saggy stance
Do you think it will continue to sag worse?
What is the measurement between the rear axle & frame?
Will you loose important wheel clearance in the front if you drop to a shorter front spring, to match the existing rear lift?
Get a damn winch!
Mon Jan 01, 2018 5:40 pm |
Re: Saggy stance
....I'm interested in your Old Saggys!
Tue Jan 02, 2018 10:51 am |
Re: Saggy stance
Tue Jan 02, 2018 5:21 pm |
Re: Saggy stance
Tue Jan 02, 2018 6:31 pm |
Re: Saggy stance
Maybe you could hang some truck nuts off the front bumper to help your saggy problem.
Tue Jan 02, 2018 7:27 pm |
Re: Saggy stance
Well, got a helluva good deal on a Warn winch at 4WP sale this week end.
Also, while working on the rear end this week end i found that the axle shim on the driver’s side had rotated such that it was almost perpendicular to the leaf springs. Pounded it back in line which should help a little.
We’ll see what the winch does.
Mon Mar 12, 2018 7:02 pm |
Re: Saggy stance
Mon Mar 12, 2018 7:22 pm |
Re: Saggy stance
Tue Mar 13, 2018 5:18 am |
Re: Saggy stance
.[/quote]
I set the torque wrench to “stupid tight”[/quote]
Both of my son's favorite torque setting as well...
Tue Mar 13, 2018 7:13 am |
Re: Saggy stance
Well, I think I found the real culprit.
Thu Mar 15, 2018 6:32 pm |
Re: Saggy stance
Thu Mar 15, 2018 7:20 pm |
sykanr0ng
Re: Saggy stance
Heavy Duty Boomerang styled rear spring shackles.
Thu Mar 15, 2018 8:30 pm |
Re: Saggy stance
I'll bet that was making a little racket!
Fri Mar 16, 2018 7:02 am |
Re: Saggy stance
Fri Mar 16, 2018 10:00 am |
Re: Saggy stance
Fri Mar 16, 2018 10:02 am |
[ 22 posts ] |
Users browsing this forum: No registered users and 41 guests |
