www.ColoradoClassicBroncos.com - View topic - Rear suspension advice
It is currently Sat Nov 23, 2024 12:38 pm
Reply to topic  [ 31 posts ]  Go to page 1, 2  Next
Post Rear suspension advice
I’m loaded for Baja and have fairly decent squat that’s going to cause handling issues on the highway. Think about 2 options; add an overload spring or add an air shock on 1 of my 2 rear shocks. If air shock, should I replace the forward or aft?
Advice/suggestions? ImageImage
Go Hard or Go Home
Mon Apr 09, 2018 4:14 pm
Post Re: Rear suspension advice
I would use coil over load shocks on the position. Air shocks can be unreliable I've seen a few failures.
Mon Apr 09, 2018 7:54 pm
Profile WWW
Go Hard or Go Home
Mon Apr 09, 2018 8:13 pm
Have you thought about Air Lift or Firestone load leveler air bags?
Mark.
Mon Apr 09, 2018 8:22 pm
Go Hard or Go Home
Mon Apr 09, 2018 8:52 pm
Tue Apr 10, 2018 8:37 am
I wonder if you could come up with a design that hangs the air bag from the frame with a contact plate on the axle so they only contact each other when you are loaded down. Then flexing isn't an issue.
Have you driven it this way? I am sure you'll be doing some whoops and the like in the desert, so I'd be more worried about that unless it's just so overloaded that it's squirrelly at speed.
I'm not sure that a shock mount would take the abuse of extra weight, so I too believe airbags would be your best bet.
Another avenue to explore might be a rear sway bar??
Tue Apr 10, 2018 9:31 am
One of the things I found in my googling last night, were these mounts from Daystar I think it solves the long travel issue. I'm still not sure what bags, etc to match with them or if this is the way I'm going. I have an appointment with Denver Spring and Suspension on Friday morning to let them take a look. It definitely needs to be addressed before Baja, and I'm quickly running out of time.
Go Hard or Go Home
Tue Apr 10, 2018 10:55 am
There ya go! Looks like a great solution that would require a little fabbing to work.
These also might be worth a look, but I'm not sure they are designed to "carry" a load.
http://timbren.com/active-off-road-bumpstops/
Tue Apr 10, 2018 10:59 am
I just got off the phone with Daystar and they were VERY helpful -- these cups are a simple install and can handle up to a 6" dia bag. I made a command decision and ordered a set and they'll be here in a few days. I just need to figure out how to size the bags now.
Go Hard or Go Home
Tue Apr 10, 2018 11:07 am
For durability down Baja and back I don't think air bags would be a good choice at this time. I've never seen a manufacturers kit designed for the rear of an early Bronco. That means you'll end up with a custom setup that has not been tested, anywhere, ever. I would keep the solution simple. The overload shocks or even short, solid lift blocks would be better.
Tue Apr 10, 2018 11:13 am
Go Hard or Go Home
Tue Apr 10, 2018 11:44 am
I’ve got those 1” blocks I just took off Gunni if you’d like to include them in your option list.
Tue Apr 10, 2018 12:39 pm
Go Hard or Go Home
Tue Apr 10, 2018 12:44 pm
let me know what Denver Spring says, i might consider it as well depending on final weight
Tue Apr 10, 2018 4:27 pm
Go Hard or Go Home
Tue Apr 10, 2018 4:30 pm
Has anyone ever used these?
Go Hard or Go Home
Wed Apr 11, 2018 5:51 pm
Images: 1
I have used both ad a leaf and over load coils over shocks both worked for carry load ,the coils over shocks don't hurt flex as much ,I have looked into a air bag { just one in center } but room and size of bag seem like lots of re designing for just 3 times a year that we carry extra load ,
Wed Apr 11, 2018 7:41 pm
Thu Apr 12, 2018 7:02 am
Did your decide what you are going to do?
In the future when you employ the airbag pads I’d like to be involved as I have similar plans for BSD.
Thu Apr 12, 2018 8:55 am
Thu Apr 12, 2018 9:12 am
Go Hard or Go Home
Thu Apr 12, 2018 6:54 pm
Go Hard or Go Home
Thu Apr 12, 2018 6:55 pm
Go Hard or Go Home
Thu Apr 12, 2018 6:59 pm
Hi, I'm relatively newish around here, but but I believe there is another perspective you really should consider. K.I.S.S. Maybe the problem isn't that your rear suspension is sagging, it's that your asking it to do too much. I cannot think of any aspect of an overloaded vehicle that's really a positive. Handling, safety, reliability.. I just don't see any of those aspects that are really improved with any of the potential solutions that have been suggested. Pack like your going on a long backpack trip using your ingenuity and creativity.
Or steal a little inspiration (probably way easier):
http://www.pirate4x4.com/forum/jeep-wil ... 503?page=1
This is his build thread, but 2/3rds of the way in he starts talking about his Ultimate Adventure trip. Long story short, his flat fender jeep has nowhere to put stuff and isn't built to carry aloe of weight, so he gets very resourceful about what he and his copilot take with them.
BTW, my experience with Denver Spring is kinda related, by not really. I needed a set of rear leaf spring re-arched to add a little height to my Mustang. The rear Springs were new, but just a touch too low at ride height. The quote I got was $800 off of the car, and double with removal and install. I just couldn't justify spending that to tweak a $300 pair of springs.
Fri Apr 13, 2018 2:40 am
Go Hard or Go Home
Fri Apr 13, 2018 9:39 am
Go Hard or Go Home
Fri Apr 13, 2018 9:41 am
Fri Apr 13, 2018 9:57 am
Go Hard or Go Home
Fri Apr 13, 2018 9:59 am
Yup. It's all about finding the compromise that works for you.
I have had an add a leaf on my old Ranger and now my Explorer. Neither have had a problem with how they worked but I don't haul or tow anything. They are a cheap way to lift the rear on a torsion bar ford, along with a torsion twist in front. They do seem to shorten the leaf springs life. I'm on the 3rd set of explorer leafs now. I just keep an eye on them.
I have heard good things about Denver Spring quality, which is what led me there in the first place. I suspected the quote was off, but found a better solution anyways. I'd go back in the future as no one else local does what they do.
Fri Apr 13, 2018 1:26 pm
32,973,335 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
