www.ColoradoClassicBroncos.com - View topic - Engine Woes
It is currently Sat Nov 23, 2024 10:29 am
Reply to topic  [ 11 posts ]
 Engine Woes
Post Engine Woes
Engine Woes! My stock 302/2bbl is cramping out. Main bearings are down to the copper. Here’s the problem- I’m broke.
I don’t need/can’t afford a coyote. It’s a 75, driver- camping at high altitude, some wheeling, occasionally pulling my ATV or pop up. Looking at budget-friendly options and I need some feedback. Suggestions appreciated- or cheap 351’s...:)
In Elizabeth, CO in case anyone knows of any deals locally. I can’t drop 3-5k on this. Looking for creative ideas. Also- I’m not doing the work. Replacing a motor is out of my skill set and existing tool/garage capacity. TIA for any ideas or leads!
Mon Apr 16, 2018 9:25 pm
Post Re: Engine Woes
I would surf Craigslist for a running 302 and do a direct swap. Might be the easiest and quickest fix.
Mon Apr 16, 2018 9:56 pm
Avoid the 351 if you're on a budget. Little details like exhaust mods and the like will nickel and dime you.
Mon Apr 16, 2018 9:59 pm
How about a relatively low mile (144K) 99 explorer 5.0 that runs great? No efi or serpentine drive. $200 if you can wait a month. You can see it run up until that time.
Tue Apr 17, 2018 2:16 pm
That’s the ticket, right there!
Go Hard or Go Home
Tue Apr 17, 2018 3:08 pm
Ditto
Tue Apr 17, 2018 6:32 pm
Go Hard or Go Home
Tue Apr 17, 2018 6:43 pm
Tue Apr 17, 2018 6:57 pm
Tue Apr 17, 2018 8:56 pm
Greeley.
I also forgot you will need a steel distributor gear.
Wed Apr 18, 2018 12:42 am
Wed Apr 18, 2018 6:51 am
32,972,059 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
