www.ColoradoClassicBroncos.com - View topic - Deciphering front end analysis
It is currently Fri Nov 22, 2024 10:00 pm
Reply to topic  [ 20 posts ]
Post Deciphering front end analysis
I’m trying to figure out why my Stroppe seems to be wandering more than it should, so I took it down to make sure toe in was perfect. They gave me this analysis sheet that I’m trying to figure out. It “looks” like I’ve got negative caster? Is that a correct read? Image
Go Hard or Go Home
Fri Apr 27, 2018 12:29 pm
Post Re: Deciphering front end analysis
You need to talk to Digger. He'll explain so those numbers and then some.
That said, I believe you have positive caster on each side but it's the cross caster that is negative. Cross caster is how far off the sides are from each other. What that value really means though, Digger would need to explain.
Fri Apr 27, 2018 12:53 pm
hey Scott you need to increase your positive caster by a couple of deg. when you don't have all the positive caster that you need the vehicle can feel unstable and when you side to side caster is doesn't match it can feel funny when you brake and on road that have a lot of road crown. C bushings and radius arm bushings.
Fri Apr 27, 2018 1:20 pm
Profile WWW
Your caster is at 2.3* POSITIVE on the driver's side and 2.6* POSITIVE on the passenger side. As has been said you need to swap out your radius arm bushings for some with more caster designed in. The negative value you are seeing is the cross caster. Not a big enough difference for you to notice. Cross caster helps with keeping you going straight on a crowned road, ideally. That small of a difference would not be noticeable, in these old broncos, realistically.
I like 7*-8* of positive caster myself but that would kill your driveshaft angle. I would shoot for 4*-5* if you can get there with the available bushings for your lift height and driveshaft angle. You'll have to find out what bushings you have currently installed before you can figure out what bushings you need.
Fri Apr 27, 2018 1:42 pm
Thx - I’m assuming the only way to determine existing caster in bushings is to yank them off? Are they stamped?
Go Hard or Go Home
Fri Apr 27, 2018 3:52 pm
Fri Apr 27, 2018 4:02 pm
3.5” lift -
Go Hard or Go Home
Fri Apr 27, 2018 4:09 pm
Your Caster is +2.3° Drivers / +2.6° Passenger. The report shows RED because it is out of spec.(Low) . I like to be on the high end of that with 3-5°, similar to other modern power steering equipped vehicles.
Camber looks OK for a Bronco. Factory was 1.5°. The truck will pull to the side with higher positive camber. Right in your case. However the lower caster on the driver's side will counter the camber pull on the passenger side.
Toe is fine number-wise. However, if you have heavily offset wheels or tires that stick out a ways, the truck can dynamically toe-out due to the drag of the tires while driving. The drag tends to stretch/straighten the tierod, load the tie-rod ends, etc resulting is loss of toe-in, which can make the trunk wander as toe approaches zero.
I would start with fixing the Caster. Yes, you will have to pull radius arm bushings. If that doesn't completely fix it, bump the toe up to .37°, but no more than .50° (total toe) Between these two angles, it should noticeably improve any wandering issues.
One other factor might be tire pressure. It's routine for alignment shops to check tire pressure before alignment. If they set your pressure at 32psi, that is likely too high for big tires. The bigger the tire, the less pressure needed to support the truck. Too high and its like driving on ice skates, the truck will wander from riding on only the center of the tire patch. My 37's are down to 26psi on the street to get full contact. Higher than 28psi and Im all over the lane at interstate speeds.
Fri Apr 27, 2018 4:15 pm
Fri Apr 27, 2018 4:20 pm
Go Hard or Go Home
Fri Apr 27, 2018 4:28 pm
Fri Apr 27, 2018 4:45 pm
Looks like Those bushings are a 2 person job especially without s lift. Any shops in town that we trust to do that work?
Go Hard or Go Home
Fri Apr 27, 2018 5:00 pm
I think you may be out of time for a bushing swap. It would be a most of the day swap if you had new ones. The old ones could even be 7 degree already.
Too many people trying to get too many things done at the very last minute right now.
Fri Apr 27, 2018 7:13 pm
Go Hard or Go Home
Fri Apr 27, 2018 7:21 pm
Jeff says to bring your bushings, Bronco and his aluminum jack stands over to his place tomorrow and we will make it happen.
Fri Apr 27, 2018 7:37 pm
Go Hard or Go Home
Fri Apr 27, 2018 7:51 pm
Phil, I think I saw you headed south on I25 around noon today near Longmont
Fri Apr 27, 2018 8:53 pm
Fri Apr 27, 2018 9:23 pm
Go Hard or Go Home
Fri Apr 27, 2018 9:32 pm
Just installed a new set of heads last night. Might be rebuilding a transmission tomorrow.
Fri Apr 27, 2018 9:34 pm
Users browsing this forum: No registered users and 39 guests
32,959,778 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
