www.ColoradoClassicBroncos.com - View topic - Ring and Pinion opinions
It is currently Fri Nov 22, 2024 11:53 am
Reply to topic  [ 13 posts ]
Post Ring and Pinion opinions
I’ve got to replace the R&P in my 9”. Any opinions on brand? I assumed I would go with Yukon, but for no particular reason. Thought I would throw it out there for feedback.
Go Hard or Go Home
Mon May 21, 2018 2:17 pm
Post Re: Ring and Pinion opinions
This thread just got bumped today: http://www.pirate4x4.com/forum/general- ... and-3.html
The chart halfway down the page is claiming Spicer gears to be far and away the best. Then a couple others better than Yukon. Having seen that; I've installed a heck of a lot of ring and pinions and I've always liked the pattern I've gotten from the Yukon gears. I've never gotten a noisy set from any manufacturer and I've never seen a failure in my gear installs. I just installed Yukon cheapies(USA standard) in the rear of my pickup truck and Dorman gears in the front. I haven't put it in 4wd to listen to the front gears but the rears are quiet and I got a good pattern on both gear sets. In my latest bronco craziness I've got Richmond gears in the front(only thing offered for a true hi9) and I installed Yukon gears in the rear 3rd. Both sets look well made and have nice patterns.
Mon May 21, 2018 6:48 pm
Go Hard or Go Home
Mon May 21, 2018 7:04 pm
I just put usa standards in my bronco. Only have a 100 miles or so on the rear but they are quiet. The fronts havent been under power but hubs locked (on coast side) they are quiet.
Mon May 21, 2018 7:41 pm
Western Driveline in Aurora is a distributor, not sure what they sell them for, last set I purchased was online.
Mon May 21, 2018 8:28 pm
Tue May 22, 2018 7:38 am
Tue May 22, 2018 10:20 am
Tue May 22, 2018 11:39 am
Tue May 22, 2018 1:45 pm
Oh wow! Where is my head!! I stand corrected!
Tue May 22, 2018 2:38 pm
You definitely need to replace bearings. There was a lot of metal in the oil.
Tue May 22, 2018 3:54 pm
Go Hard or Go Home
Tue May 22, 2018 5:55 pm
Sat May 26, 2018 10:25 am
32,949,632 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
