www.ColoradoClassicBroncos.com - View topic - Throttle Body Position
It is currently Fri Nov 22, 2024 12:19 pm
Reply to topic  [ 9 posts ]
Post Throttle Body Position
I have a 96 Explorer EFI set up and was checking clearance for the throttle body and the hood will not close in the OEM position (pic1) is there any reason that I shouldn't rotate it 180 degrees? (pic 2).
Thu May 24, 2018 1:51 pm
Post Re: Throttle Body Position
You can rotate it.
Thu May 24, 2018 2:04 pm
Great news! Thanks for the reply
Thu May 24, 2018 2:09 pm
I took that EGR stuff off of mine and ran the throttle body straight off the riser/plenum.
Fri May 25, 2018 1:23 am
Fri May 25, 2018 6:26 am
I have a non-egr lower inake that you can have along with the upper intake it you want it?
I need an aux tank skid plate???
Fri May 25, 2018 9:12 am
Fri May 25, 2018 9:53 am
The one with an EGR has a hole in the center of the lower that you should plug. I tapped and screwed a pipe plug in it. The ones without an EGR don’t have the hole.
Fri May 25, 2018 12:23 pm
My lower intake has NO HOLE to plug.
I don't know about the EGR from beans!?!?
...but definitely 1 more electronic thingy you can DELETE!
Fri May 25, 2018 1:07 pm
Users browsing this forum: No registered users and 28 guests
32,950,221 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
