www.ColoradoClassicBroncos.com - View topic - speedometer woes.
It is currently Fri Nov 22, 2024 12:18 pm
Reply to topic  [ 11 posts ]
 speedometer woes.
Post speedometer woes.
With my recent regear my speedometer is now fast. By about 18%. So doing the math I's need a 24 tooth driven gear. Well they only make a 21 max. Current is 20teeth. Not sure what the drive gear tooth count is. Any ideas on how to correct it with out buying a new digital cluster?
Thu May 24, 2018 4:33 pm
Post Re: speedometer woes.
Bigger tires?
Fri May 25, 2018 8:40 am
Phone GPS/Speedo?
Fri May 25, 2018 9:07 am
Replace the speedo drive gear on the output shaft with a 6 tooth version.
Fri May 25, 2018 9:32 am
Fri May 25, 2018 3:30 pm
Fri May 25, 2018 3:31 pm
I'll trade ya if you do.
Fri May 25, 2018 3:32 pm
Let's make sure you have a 7 first. What color is the gear?
Fri May 25, 2018 3:47 pm
Sat May 26, 2018 8:55 am
Sat May 26, 2018 9:30 am
Phil I'll give you a call Monday and can run up then. Gotta stick around to this side of town as I have the electronic leash until then.
Sat May 26, 2018 1:33 pm
Users browsing this forum: No registered users and 26 guests
32,950,194 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
