www.ColoradoClassicBroncos.com - View topic - Disc brakes for 9” - explorer if possible.
It is currently Sun Nov 24, 2024 4:05 pm
Reply to topic  [ 11 posts ]
Post Disc brakes for 9” - explorer if possible.
Looking to convert a ford 9” big bearing rear end to disc brakes, probably would prefer the explorer setup. Do not need ebrakes.
Wed Jun 20, 2018 8:15 am
Post Re: Disc brakes for 9” - explorer if possible.
If only there s a member in Greeley that has a pseudo Explorer graveyard....
Wed Jun 20, 2018 9:49 am
Unfortunately they don't bolt on to the HD axle. They can be made to fit though.
Wed Jun 20, 2018 6:30 pm
Wed Jun 20, 2018 9:06 pm
Wed Jun 20, 2018 9:13 pm
Yes and the axle tube ends have the torino bolt pattern. That is the same as the 74-75 medium duty axle.
You can buy a kit that has everything already converted which is the way I would go.
Wed Jun 20, 2018 9:15 pm
Wed Jun 20, 2018 9:16 pm
Thu Jun 21, 2018 6:11 am
Thu Jun 21, 2018 7:15 am
I'll be waiting for the write up. icon biggin
TJ
F. Scott Fitzgerald
Fri Jun 22, 2018 8:49 pm
Get. It all from pull and pay, new lines from Currie and spacer rings....cheapest route. Torino ends make it easy...key holing to fit larger is not too hard either
Sun Jun 24, 2018 8:07 pm
33,006,307 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
