It is currently Sun Nov 24, 2024 3:55 pm
rt9
Re: Garage build
Sat Mar 24, 2018 7:55 am |
Re: Garage build
It’s a penetrating sealer, cheapest place I could find it was online. Looked at other options but this seem to be the best for what I wanted, within my timeframe and budget. I read a bunch of threads on garage journal since that’s where most of those flooring dudes hang out.
Sat Mar 24, 2018 8:04 am |
rt9
Re: Garage build
Sat Mar 24, 2018 8:45 am |
Mr. Lav
Joined: Sun Apr 17, 2011 11:33 am Posts: 200 Location: yoder, colorado
Re: Garage build
Where did you get the garage roll up door?
Sun Mar 25, 2018 7:15 pm |
Re: Garage build
Sun Mar 25, 2018 11:09 pm |
Mr. Lav
Re: Garage build
Thanks
Mon Mar 26, 2018 9:14 am |
Garage build
Passed final in April, got the outside painted and gutters put on. Hung the heater now that it’s summer lol, will install the vent and hook it up in the fall. Also finished insulating the remaining two walls and put up OSB. Also pulled speaker wire to all four corners and network cable to three of the corners for IP security cameras. The roof insulation and OSB will be a huge pain so will probably hire that out right before winter.
Tue Jun 12, 2018 8:08 am |
Re: Garage build
Nice work. I like the OSB walls. Must be a huge contrast. Still can't believe all you did in the old single car garage.
Thu Jun 14, 2018 9:39 pm |
Re: Garage build
Sun Jun 17, 2018 4:33 pm |
Re: Garage build
Chris,
I think you ran an internet connection to your garage. I'm getting ready for earthwork now. They will trench from the house to the garage for electric service and gas. What is the best way to run an ethernet/internet connection to the garage? Wire type? Conduit or direct bury? Separation distance from electric service wire?
Thanks.
Sun Jul 01, 2018 10:14 am |
Re: Garage build
Sun Jul 01, 2018 10:39 pm |
Re: Garage build
Thanks for the info!
Tue Jul 03, 2018 6:58 pm |
Users browsing this forum: No registered users and 26 guests |
