Black Smoke Donkey
Re: Black Smoke Donkey
Postby cpldavis37 » Mon Jan 29, 2018 1:51 am
I was at 4 wheel parts buying a new Odyssey and I told the guy it was for my Bronco. He pulled his phone and showed me a picture of BSD and told me it was the craziest Bronco he had ever seen in a parking lot. I told him that the owner and Mad Scientist who built it was is a friend of mine. Looks like you've got some secret admirers at 4 wheel parts.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Kinder » Mon Jan 29, 2018 6:19 am
Ha, I can’t hide anymore. I was up there buying a new drop hitch if it was a recent picture. With the addition of the D60 and 37s my old hitch wouldn’t work with my little utility trailer that I was keeping the camper on.
With 35s and 9”
With 37s and D60
Postby cravenbronco » Mon Jan 29, 2018 8:22 am
Wow what a difference. Looks good Kirk.
cravenbronco
Postby Jesus_man » Mon Jan 29, 2018 8:26 am
What a machine!
Postby Eck » Mon Jan 29, 2018 9:33 am
It’s crazy that bigger tires and axles can make the fenders almost look white!! I’m sure you get lots of lookers when your out and about.
Postby Strike2 » Mon Jan 29, 2018 1:27 pm
Those 37's look great with the Prerunner fenders thumbs up
Strike2
Postby Kinder » Fri Aug 03, 2018 10:16 am
While trying to overcome my sadness on not being able to make the wheeling trip this weekend I decided to pull out all my junk that l’ve set aside for the front axle upgrade on BSD. Now I just need to find some time between family, school and work to get it started, I’ll probably just shove it all in the corner, wish me luck.
Postby mickphatmac » Fri Aug 03, 2018 10:24 am
Bronco, family, Bronco, school, Bronco and work...
You're a BEAST!!!
Postby Strike2 » Fri Aug 03, 2018 11:47 am
[quote="Kinder"]While trying to overcome my sadness on not being able to make the wheeling trip this weekend I decided to pull out all my junk
This sounds like the first step to either a great BUILD thread or a really bad XXX movie icon biggin
Strike2
Postby colby45 » Fri Aug 03, 2018 8:16 pm
If you need an extra set of hands to get things cranked out, let me know!
Sally
'66 Halfcab
colby45
Images: 2
Postby Kinder » Sat Aug 04, 2018 11:21 am
colby45 wrote:If you need an extra set of hands to get things cranked out, let me know!
Will do, when I get to the part where I try to get it under the Bronco I’d appreciate the help.
Postby colby45 » Sat Aug 04, 2018 7:24 pm
Kinder wrote:Will do, when I get to the part where I try to get it under the Bronco I’d appreciate the help.
I can do that! Just let me know when. Now that summer is winding down, so is my schedule.
Sally
'66 Halfcab
colby45
Images: 2
Postby Kinder » Sat Aug 11, 2018 7:08 am
Found a few minutes to tear the D60 down a bit more; hubs, spindles, axles and diff out. New high steer arms with integrated springless kingpin adjustment installed (the stock spring loaded bushing/bearing tension system doesn’t work with big tires) and I also mocked up the tie rod. Next is ARB and gear change, while continuing to massage the C wedges into shape.
Postby Strike2 » Sun Aug 12, 2018 6:47 am
Very nice , every little bit of garage time adds up to compleation thumbs up
Strike2
Postby Kinder » Wed Sep 19, 2018 3:50 pm
BSD did it’s annual parks volunteer work, used the winch to pull out two telephone poles that were stringers for a pedestrian bridge. I’ll guess they weighed around 750-1000 lbs each. This will be the third bridge I’ve replace at Roxborough. I’m grateful that Jake, a VOC volunteer, helps me with them, he’s been doing this kind of work for 60 years and is a great mentor.
Postby Jesus_man » Thu Sep 20, 2018 9:09 am
Sure makes a great work horse!!
Postby Kinder » Tue Oct 16, 2018 7:01 am
Always happy when my mud tires get muddy.
Postby Jesus_man » Tue Oct 16, 2018 8:50 am
What a great setup!! Who's running around on chains?
Postby Kinder » Tue Oct 16, 2018 9:02 am
Jesus_man wrote:What a great setup!! Who's running around on chains?
All the hunters with street tires, it was a sloppy mess getting in before the season started. Luckily it started to dry out when we were leaving.
Postby rt9 » Tue Oct 16, 2018 7:26 pm
Kinder wrote:Always happy when my mud tires get muddy.
So cool! Love the Pinto.
rt9
Images: 11
Postby Kinder » Thu Nov 15, 2018 5:43 pm
If I never do another D60 ARB install it’ll be too soon, of course I still have the rear axle to do, ha.
And how many adapters does it take to go from 1/4” drive to 3/4” drive so I can check the pinion preload? The same number of licks it takes to get to the center of a tootsie pop, three.
Postby Jesus_man » Fri Nov 16, 2018 8:15 am
Fun!
Postby Rox Crusher » Fri Nov 16, 2018 10:44 am
I am about to impart some very vague and uninformed wisdom..........
the O-rings on the ARB in my 9" diff started leaking during our last wheeling trip. leaking so bad the locker wouldn't stay engaged and the compressor stayed running forever and pushed a bunch of oil out of the diff. My ARB probably only have 15k miles on them.
I was talking to Jason about it and he said that Spidertrax had (may still have?) some upgraded o-ring / sealing solution to prevent this.
I haven't had time to look into it further but will be doing so over the winter
probably not critical on the front since carrier isn't always spinning but the rear is another story
Postby Eck » Fri Nov 16, 2018 10:47 am
My O-ring on my rear start leaking in Baja as well. Doesn’t sound as bad as Jeff’s but it was pushing oil up through the solenoid.
I’d be interested in knowing what this upgrade is as I will probably look to fix it later this winter as well.
Postby Rox Crusher » Fri Nov 16, 2018 10:50 am
Eck wrote:My O-ring on my rear start leaking in Baja as well. Doesn’t sound as bad as Jeff’s but it was pushing oil up through the solenoid.
I just sent an email to spidertrax asking if they have something
Postby Viperwolf1 » Fri Nov 16, 2018 1:28 pm
Probably got some bad fish tacos.
Postby Eck » Fri Nov 16, 2018 2:33 pm
Well played.
Postby Kinder » Fri Nov 16, 2018 4:29 pm
Please share the results, I just put an ARB in Willem’s 9” this last year. I can say the seals are the same design regardless of differential type, but the setup is completely different.
Rox & Eck, how long (years and/or months) have you been running them before the leak started?
Postby Rox Crusher » Fri Nov 16, 2018 5:49 pm
Mine have been in for 3 years
When did you install them ?
Postby ZOSO » Fri Nov 16, 2018 7:56 pm
Mine works great but I just put it in this year. Curious as to what this fix is. Did anyone contact ARB about the issue?
