It is currently Thu Nov 21, 2024 11:01 pm
[ 7 posts ] |
mustangjonny84
Joined: Sun Apr 10, 2016 4:06 pm Posts: 48 Location: Longmont
D44 Warn locking hubs
Last winter, I had some issues with my current hubs. I know a lot of you guys know my truck better than I do so I'm looking here for help. Pictured below is what I've got now. My front axle is a "79' Bronco dana44 highpinion with 76' f250 knuckle out". I'd like to get Warn Premium locking hubs. Being Frankenstein's monster, I'm just not sure which one to go with. Some sites say the Warn 9072... Some sites say the Warn 20990... From what I've read so far, the difference has to do with the outer diameter of the axle shaft. Any ideas so that I can make the purchase before taring into my axle??
_________________ 1975 Bronco- 302 w/ EFI,NP435,twin stick D20, D44, D60, 4.5" WH lift, 1" body lift, 35" Nitto Trail Grapplers 2012 Flex Ecoboost - VTA mod 2003 Mustang Mach 1- K&N,SSS catback 1992 GMC Bread Van - wife's food truck... 2003 Suzuki SV1000- GSXR fork,Danmoto cans,carbon fiber fender, lots of stuff painted black 1980 CB750 cafe- GSXR fork,K&N,CBR coil packs,Chappell customs seat,MAC 4/1 exhaust
Last edited by mustangjonny84 on Thu Aug 09, 2018 12:07 pm, edited 1 time in total.
Mon Aug 06, 2018 6:07 pm |
Re: D44 Warn locking hubs
Before you replace, you should pull them apart and have a look-see. Perhaps it's an easy fix? Sometimes even too much grease creates more vacuum then the spring can overcome (especially in the cold) and all that is needed is a good cleaning and a light coating of lithium grease.
But based on internet pics, those look like stock F-250 hubs.
Tue Aug 07, 2018 8:39 am |
RJLougee
They both fit the 19 spline axles, so it's not an axle shaft size issue.
The #20990 is designed for the standard internal locking hubs like we have on the EB.
The #9072 is designed for the external locking hubs commonly found on the 3/4 ton trucks (not the 1 ton, D60 setup).
I cannot tell which you have looking at the pic. Maybe a shot from the side without a wheel on? HTH, Joe
Wed Aug 08, 2018 9:19 pm |
mustangjonny84
Here's a side view of my current hub...
Thu Aug 09, 2018 11:48 am |
sykanr0ng
That sure looks like a heavy duty Spicer hub that was used on the highboy F250
Thu Aug 09, 2018 3:08 pm |
RJLougee
That still looks like an external assy. However, I'm only 85% sure, not 100%.
Can we get a pic without a wheel on there? Joe
Tue Aug 14, 2018 7:59 pm |
mustangjonny84
Wed Aug 22, 2018 8:21 pm |
[ 7 posts ] |
