[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 379: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
www.ColoradoClassicBroncos.com - View topic - 'Buddy'
It is currently Thu Nov 21, 2024 8:31 am
Reply to topic  [ 253 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
 'Buddy'
Post Re: 'Buddy'
What fuel rail will you be using and how will you handle return fuel ?
Look forward to helping on the project !
Thu Aug 30, 2018 7:19 pm
Post Re: 'Buddy'
I’ve got the fuel rail with the return line, planning to plumb it the same way as the supply and run a fuel hose to a T fitting in the filler vent tube.
Thu Aug 30, 2018 9:55 pm
Post Re: 'Buddy'
Day 1 of the EFI swap is in the books. The motor was stripped of the carb, intake, heads, and, ignition system. The computer has a new home in the firewall. The back half of the fuel lines are plumbed. The GT40P heads, lower intake, fuel rail, and valve covers are on. Tomorrow the goals are to make the fuel lines for the engine bay, get the wiring squared away, change the oil, and finish up a couple of other random projects.
Huge thanks to Jeff (Mr. Right Stuff), Phil (ANfittingsdirect’s biggest fan), Jeremy, Chuck, Rob, Steve (the firewall slayer), Chris, and Adam for shuttling the computer from EFI Guy.
Sat Sep 01, 2018 10:40 pm
Post Re: 'Buddy'
Awesome! I will see you Sunday
Sun Sep 02, 2018 12:55 am
Post Re: 'Buddy'
Looks good. Wish I could have stuck around for a bit.
Sun Sep 02, 2018 6:29 am
Post Re: 'Buddy'
Looking good! Wish I could join in on the fun. I'll be patiently awaiting a good burnout video.
Sun Sep 02, 2018 8:54 am
Post Re: 'Buddy'
Sun Sep 02, 2018 10:43 am
Post Re: 'Buddy'
Sun Sep 02, 2018 10:53 am
Post Re: 'Buddy'
I can’t begin to thank Phil, Jeremy, Jeff, John, Chuck, Kevin, Shawn and everyone that came over yesterday enough for their hard work this weekend. Today, the wiring, fuel lines, upper intake and a few other side projects got wrapped up and allowed Buddy to go for a drive tonight. I can’t believe the difference in how it drives. It’s like a completely different vehicle. This weekend also uncovered a few items that will be addressed soon. For now, I’m just very thankful for this group and everyone’s willingness to help because a project like this would’ve taken me an unbelievably long time to do myself, and even then it wouldn’t be done as well as this is.
I’ll get some additional pictures tomorrow but here are a couple showing the progress.
Sun Sep 02, 2018 10:52 pm
Post Re: 'Buddy'
Nice! Very cool. Way to knock it out.
Mon Sep 03, 2018 8:34 am
Post Re: 'Buddy'
Mon Sep 03, 2018 9:50 am
Post Re: 'Buddy'
Mon Sep 03, 2018 9:54 am
Post Re: 'Buddy'
Nice! Great job guys.
Love the 1999 flip phone video! Classic
Mon Sep 03, 2018 5:51 pm
Post Re: 'Buddy'
Looks awesome Tim!
Glad to hear the EFI swap is complete and up an running, defiantly lots and lots of bronco knowledge in your garage the past few days. Wish I could have been there for the tutorial on the wiring!
Tue Sep 04, 2018 2:27 pm
Post Re: 'Buddy'
A couple more pics from the weekend. One is the coolant overflow/washer tank mounted on the front of the driver’s side fender. Second is the fuel pump/filter setup. I’m running the e2000 frame mounted pump from late ‘80s Bronco/F-150 without the low pressure pump to feed it.
Tue Sep 04, 2018 11:10 pm
Post Re: 'Buddy'
Looks great Tim!, which year model is that overflow/washer tanks from?. Also here is the info in K&K surplus give them a call on what you need it might be a little closer than Dencol and since you've never been its a cool place to visit and walk there used scrap yard lots of cool stuff to check out.
http://www.kksurplus.com/
Thu Sep 06, 2018 10:08 am
Post Re: 'Buddy'
That washer/coolant tank is from any 90's F series or Bronco - they are plentiful in the pull n pays, might take a while to find one that isn't totally trashed
Thu Sep 06, 2018 10:15 am
Post Re: 'Buddy'
Thu Sep 06, 2018 10:58 am
Post Re: 'Buddy'
Thu Sep 06, 2018 6:11 pm
Post Re: 'Buddy'
Started cleaning up some wiring today and thought I would install my new mirror.
Thu Sep 06, 2018 6:12 pm
Post Re: 'Buddy'
Daaaaang that's fancy! I was doing good to install one with a maplight in it and convert it to LED.
Thu Sep 06, 2018 7:02 pm
Post Re: 'Buddy'
You’ve been sitting on that upgrade for a while!! Looks nice.
Thu Sep 06, 2018 7:47 pm
Post Re: 'Buddy'
Yeah it's been low on the priority list. For $7 at the pick n pull, its pretty sweet.
Thu Sep 06, 2018 7:55 pm
Post Re: 'Buddy'
Fri Sep 07, 2018 9:25 am
Post Re: 'Buddy'
Fri Sep 07, 2018 4:48 pm
Post Re: 'Buddy'
Fri Sep 07, 2018 4:57 pm
Post Re: 'Buddy'
Mounted the MAF sensor and the relay/fuse box to the fender using some nice stainless brackets courtesy of D&D72. Thanks John!
Fri Sep 07, 2018 6:24 pm
Post Re: 'Buddy'
thumbs up
Sat Sep 08, 2018 9:44 pm
Post Re: 'Buddy'
Spent a little time working on Buddy today. I put the wiper motor cover and visors back on for the first time in a few years. I also took Phil’s advice and replaced the fan clutch with a severe duty clutch from a trailblazer. It moves the fan forward about 1.5-2 inches which means I don’t need the homemade fan shroud extension any more.
Sun Sep 09, 2018 11:06 pm
Post Re: 'Buddy'
Sweet! You'll be blazing trails in no time!!
Mon Sep 10, 2018 7:57 am
32,911,944 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
