It is currently Thu Nov 21, 2024 8:02 am
Re: 'Buddy'
What fuel rail will you be using and how will you handle return fuel ?
Look forward to helping on the project !
Thu Aug 30, 2018 7:19 pm |
BroncoRaider
Re: 'Buddy'
I’ve got the fuel rail with the return line, planning to plumb it the same way as the supply and run a fuel hose to a T fitting in the filler vent tube.
Thu Aug 30, 2018 9:55 pm |
BroncoRaider
Re: 'Buddy'
Day 1 of the EFI swap is in the books. The motor was stripped of the carb, intake, heads, and, ignition system. The computer has a new home in the firewall. The back half of the fuel lines are plumbed. The GT40P heads, lower intake, fuel rail, and valve covers are on. Tomorrow the goals are to make the fuel lines for the engine bay, get the wiring squared away, change the oil, and finish up a couple of other random projects.
Huge thanks to Jeff (Mr. Right Stuff), Phil (ANfittingsdirect’s biggest fan), Jeremy, Chuck, Rob, Steve (the firewall slayer), Chris, and Adam for shuttling the computer from EFI Guy.
Sat Sep 01, 2018 10:40 pm |
D&D72
Re: 'Buddy'
Awesome! I will see you Sunday
Sun Sep 02, 2018 12:55 am |
Re: 'Buddy'
Looks good. Wish I could have stuck around for a bit.
Sun Sep 02, 2018 6:29 am |
EFI Guy
Re: 'Buddy'
Looking good! Wish I could join in on the fun. I'll be patiently awaiting a good burnout video.
Sun Sep 02, 2018 8:54 am |
Re: 'Buddy'
Sun Sep 02, 2018 10:43 am |
EFI Guy
Re: 'Buddy'
Sun Sep 02, 2018 10:53 am |
BroncoRaider
Re: 'Buddy'
I can’t begin to thank Phil, Jeremy, Jeff, John, Chuck, Kevin, Shawn and everyone that came over yesterday enough for their hard work this weekend. Today, the wiring, fuel lines, upper intake and a few other side projects got wrapped up and allowed Buddy to go for a drive tonight. I can’t believe the difference in how it drives. It’s like a completely different vehicle. This weekend also uncovered a few items that will be addressed soon. For now, I’m just very thankful for this group and everyone’s willingness to help because a project like this would’ve taken me an unbelievably long time to do myself, and even then it wouldn’t be done as well as this is.
I’ll get some additional pictures tomorrow but here are a couple showing the progress.
Sun Sep 02, 2018 10:52 pm |
Re: 'Buddy'
Nice! Very cool. Way to knock it out.
Mon Sep 03, 2018 8:34 am |
Re: 'Buddy'
Mon Sep 03, 2018 9:50 am |
BroncoRaider
Re: 'Buddy'
Mon Sep 03, 2018 9:54 am |
Re: 'Buddy'
Nice! Great job guys.
Love the 1999 flip phone video! Classic
Mon Sep 03, 2018 5:51 pm |
Strike2
Re: 'Buddy'
Looks awesome Tim! Glad to hear the EFI swap is complete and up an running, defiantly lots and lots of bronco knowledge in your garage the past few days. Wish I could have been there for the tutorial on the wiring!
Tue Sep 04, 2018 2:27 pm |
BroncoRaider
Re: 'Buddy'
A couple more pics from the weekend. One is the coolant overflow/washer tank mounted on the front of the driver’s side fender. Second is the fuel pump/filter setup. I’m running the e2000 frame mounted pump from late ‘80s Bronco/F-150 without the low pressure pump to feed it.
Tue Sep 04, 2018 11:10 pm |
Strike2
Re: 'Buddy'
Looks great Tim!, which year model is that overflow/washer tanks from?. Also here is the info in K&K surplus give them a call on what you need it might be a little closer than Dencol and since you've never been its a cool place to visit and walk there used scrap yard lots of cool stuff to check out. http://www.kksurplus.com/
Thu Sep 06, 2018 10:08 am |
Re: 'Buddy'
That washer/coolant tank is from any 90's F series or Bronco - they are plentiful in the pull n pays, might take a while to find one that isn't totally trashed
Thu Sep 06, 2018 10:15 am |
Strike2
Re: 'Buddy'
Thu Sep 06, 2018 10:58 am |
BroncoRaider
Re: 'Buddy'
Thu Sep 06, 2018 6:11 pm |
BroncoRaider
Re: 'Buddy'
Started cleaning up some wiring today and thought I would install my new mirror.
Thu Sep 06, 2018 6:12 pm |
Re: 'Buddy'
Daaaaang that's fancy! I was doing good to install one with a maplight in it and convert it to LED.
Thu Sep 06, 2018 7:02 pm |
Re: 'Buddy'
You’ve been sitting on that upgrade for a while!! Looks nice.
Thu Sep 06, 2018 7:47 pm |
BroncoRaider
Re: 'Buddy'
Yeah it's been low on the priority list. For $7 at the pick n pull, its pretty sweet.
Thu Sep 06, 2018 7:55 pm |
Strike2
Re: 'Buddy'
Fri Sep 07, 2018 9:25 am |
BroncoRaider
Re: 'Buddy'
Fri Sep 07, 2018 4:48 pm |
BroncoRaider
Re: 'Buddy'
Fri Sep 07, 2018 4:57 pm |
BroncoRaider
Re: 'Buddy'
Mounted the MAF sensor and the relay/fuse box to the fender using some nice stainless brackets courtesy of D&D72. Thanks John!
Fri Sep 07, 2018 6:24 pm |
D&D72
Re: 'Buddy'
Sat Sep 08, 2018 9:44 pm |
BroncoRaider
Re: 'Buddy'
Spent a little time working on Buddy today. I put the wiper motor cover and visors back on for the first time in a few years. I also took Phil’s advice and replaced the fan clutch with a severe duty clutch from a trailblazer. It moves the fan forward about 1.5-2 inches which means I don’t need the homemade fan shroud extension any more.
Sun Sep 09, 2018 11:06 pm |
Re: 'Buddy'
Sweet! You'll be blazing trails in no time!!
Mon Sep 10, 2018 7:57 am |
