[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 379: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
www.ColoradoClassicBroncos.com - View topic - 74 Baja Race Bronco - Baja or Bust
It is currently Wed Dec 04, 2024 2:43 am
Reply to topic  [ 309 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 11  Next
Images: 11
Post Re: 74 Baja Race Bronco - Baja or Bust
In the spirit of Chris's build, and for those that get the Elrey network on DirecTv, they have the 50th Anniversary Baja 500 Sunday at 6pm.
Tue Sep 04, 2018 6:22 pm
Post 74 Baja Race Bronco - Baja or Bust
Finished working on most of the frame, cutting off what I don’t need, track bar drop bracket, stock shock mounts etc. turned out the stock track bar bracket was junk so cut that off too and used a heavy duty drop bracket I had laying around and fabbed up a new one.
Re-enforced some spots on the frame, leaf spring hangers, radius arm frame mounts, both sides of the frame where the steering box mounts and a few other spots. Threw a quick coat of paint on it.
Mounted the rear springs, axle is under it but still have to cut out some of the back brace to make room for the spring perch and u bolts and burn in the rear brake brackets.
Working on the Dana44, should have it rebuilt tomorrow and hopefully get it mounted under the frame manãna.
Sat Sep 08, 2018 10:14 pm
Nice progress its looking good thumbs up
Mon Sep 10, 2018 6:48 am
Sure makes it a lot easier to hang that stuff onto a bare frame! Or at least, that is my assumption as I've never had that luxury!
Those lift blocks are saaaweeet!!
Mon Sep 10, 2018 8:01 am
Front end is rebuilt and re-geared and then slid it under the frame. Welded the front and rear lower shock mounts, started running fuel, brake and transmission cooling lines.
Sun Sep 16, 2018 9:22 pm
Whose leaf spring plate is that? I feel like I have some issues with mine, even tho they are extra thick...
Mon Sep 17, 2018 7:45 am
Mon Sep 17, 2018 9:20 am
Mon Sep 17, 2018 9:22 am
Mon Sep 17, 2018 9:24 am
i'll just leave these here.
Wed Sep 19, 2018 5:20 pm
Schwwwwweeeetttt!!
Wed Sep 19, 2018 5:31 pm
Nice! Did you build or have built?
Wed Sep 19, 2018 6:45 pm
Im curious to see the build sheet. So when do I pick it up.
Wed Sep 19, 2018 6:48 pm
Wed Sep 19, 2018 9:37 pm
Wed Sep 19, 2018 9:39 pm
I have a cherry picker you can borrow
Thu Sep 20, 2018 1:08 am
Thu Sep 20, 2018 6:05 am
That going to a great sounding Bronco!
In the pioneer class other than no EFI is their a limit to the motor size/hp?
Thu Sep 20, 2018 7:11 am
Thu Sep 20, 2018 8:18 am
Thu Sep 20, 2018 8:19 am
Did you get to witness the dyno run? What were the numbers? I saw some some mid 400's!!
Thu Sep 20, 2018 10:06 am
Thu Sep 20, 2018 10:31 am
Thu Sep 20, 2018 10:34 am
Let me know if you need a hand getting the engine.
Thu Sep 20, 2018 11:20 am
More stuff on the frame, engine home, viper built transmission and transfer case in temporarily.
Sun Sep 23, 2018 10:07 pm
Forgot I started to weigh stuff.
Will weigh the transfer case and transmission when I pull it again. Need to weigh the leveler to subtract it from the transmission.
Will also weigh both ends of the bronco once I have a few more things on it.
Sun Sep 23, 2018 10:37 pm
Man you are in Hyper-drive!!!! you almost have a roller its looking great thumbs up
Mon Sep 24, 2018 7:01 am
Wow, so clean!!
Mon Sep 24, 2018 7:49 am
On the other forum you said you shaved the 9 inch, do you have any pics of that?
TIA
Tue Sep 25, 2018 1:16 pm
Tue Sep 25, 2018 1:27 pm
33,209,030 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
