It is currently Wed Dec 04, 2024 2:31 am
74 Baja Race Bronco - Baja or Bust
rt9
Re: 74 Baja Race Bronco - Baja or Bust
In the spirit of Chris's build, and for those that get the Elrey network on DirecTv, they have the 50th Anniversary Baja 500 Sunday at 6pm.
Tue Sep 04, 2018 6:22 pm |
Finished working on most of the frame, cutting off what I don’t need, track bar drop bracket, stock shock mounts etc. turned out the stock track bar bracket was junk so cut that off too and used a heavy duty drop bracket I had laying around and fabbed up a new one. Re-enforced some spots on the frame, leaf spring hangers, radius arm frame mounts, both sides of the frame where the steering box mounts and a few other spots. Threw a quick coat of paint on it. Mounted the rear springs, axle is under it but still have to cut out some of the back brace to make room for the spring perch and u bolts and burn in the rear brake brackets. Working on the Dana44, should have it rebuilt tomorrow and hopefully get it mounted under the frame manãna.
Sat Sep 08, 2018 10:14 pm |
Strike2
Nice progress its looking good
Mon Sep 10, 2018 6:48 am |
Sure makes it a lot easier to hang that stuff onto a bare frame! Or at least, that is my assumption as I've never had that luxury!
Those lift blocks are saaaweeet!!
Mon Sep 10, 2018 8:01 am |
Sun Sep 16, 2018 9:22 pm |
Whose leaf spring plate is that? I feel like I have some issues with mine, even tho they are extra thick...
Mon Sep 17, 2018 7:45 am |
Mon Sep 17, 2018 9:20 am |
Mon Sep 17, 2018 9:22 am |
Mon Sep 17, 2018 9:24 am |
i'll just leave these here.
Wed Sep 19, 2018 5:20 pm |
Schwwwwweeeetttt!!
Wed Sep 19, 2018 5:31 pm |
pgilbeau
Nice! Did you build or have built?
Wed Sep 19, 2018 6:45 pm |
Im curious to see the build sheet. So when do I pick it up.
Wed Sep 19, 2018 6:48 pm |
Wed Sep 19, 2018 9:37 pm |
Wed Sep 19, 2018 9:39 pm |
I have a cherry picker you can borrow
Thu Sep 20, 2018 1:08 am |
Thu Sep 20, 2018 6:05 am |
Strike2
That going to a great sounding Bronco! In the pioneer class other than no EFI is their a limit to the motor size/hp?
Thu Sep 20, 2018 7:11 am |
Thu Sep 20, 2018 8:18 am |
Thu Sep 20, 2018 8:19 am |
Did you get to witness the dyno run? What were the numbers? I saw some some mid 400's!!
Thu Sep 20, 2018 10:06 am |
Thu Sep 20, 2018 10:31 am |
Thu Sep 20, 2018 10:34 am |
Let me know if you need a hand getting the engine.
Thu Sep 20, 2018 11:20 am |
Sun Sep 23, 2018 10:07 pm |
Forgot I started to weigh stuff. Will weigh the transfer case and transmission when I pull it again. Need to weigh the leveler to subtract it from the transmission. Will also weigh both ends of the bronco once I have a few more things on it.
Sun Sep 23, 2018 10:37 pm |
Strike2
Man you are in Hyper-drive!!!! you almost have a roller its looking great
Mon Sep 24, 2018 7:01 am |
Wow, so clean!!
Mon Sep 24, 2018 7:49 am |
sykanr0ng
On the other forum you said you shaved the 9 inch, do you have any pics of that? TIA
Tue Sep 25, 2018 1:16 pm |
Tue Sep 25, 2018 1:27 pm |
