www.ColoradoClassicBroncos.com - View topic - Blue Wrench
It is currently Sun Nov 24, 2024 2:18 pm
Reply to topic  [ 6 posts ]
 Blue Wrench
Post Blue Wrench
I'm replacing the rear springs and having trouble getting the bolts removed from the spring hangers. I suspect the bushing sleeves are rusted to the bolts and I think they'll probably need to get cut out. Does anyone have a portable blue wrench or any better ideas for getting these out? One of the four bolts are free and even a 15 lb. sledge wouldn't touch them.
Wed Oct 03, 2018 9:07 am
Post Re: Blue Wrench
I used a sawzall to get mine out
Wed Oct 03, 2018 3:14 pm
Oooo, good call Bob. Didn't even think about a sawzall. That's why I posted!
Thu Oct 04, 2018 7:10 am
Buy a good sawsall blade and go to it. I had to do the same on my 79. Ended up buying a diamond carbide blade to get those bolts cut.
Thu Oct 04, 2018 7:15 am
Thanks again fellas. Going to try to finish this up this weekend. I'm going to try to utilize some anti-seize on the sleeves/bolts in case I need to pull this apart in the near future. Anyone think that would be a bad idea? shrug
Fri Oct 05, 2018 2:06 pm
I antiseize everything.
Fri Oct 05, 2018 4:13 pm
33,003,750 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
