It is currently Thu Nov 21, 2024 8:17 am
cpldavis37
Re: Black Smoke Donkey
I was at 4 wheel parts buying a new Odyssey and I told the guy it was for my Bronco. He pulled his phone and showed me a picture of BSD and told me it was the craziest Bronco he had ever seen in a parking lot. I told him that the owner and Mad Scientist who built it was is a friend of mine. Looks like you've got some secret admirers at 4 wheel parts.
Mon Jan 29, 2018 2:51 am |
Ha, I can’t hide anymore. I was up there buying a new drop hitch if it was a recent picture. With the addition of the D60 and 37s my old hitch wouldn’t work with my little utility trailer that I was keeping the camper on. With 35s and 9” With 37s and D60
Mon Jan 29, 2018 7:19 am |
cravenbronco
Wow what a difference. Looks good Kirk.
Mon Jan 29, 2018 9:22 am |
What a machine!
Mon Jan 29, 2018 9:26 am |
It’s that bigger tires and axles can make the fenders almost look white!! I’m sure you get lots of lookers when your out and about. Sent from my iPhone using Tapatalk
Mon Jan 29, 2018 10:33 am |
Strike2
Those 37's look great with the Prerunner fenders
Mon Jan 29, 2018 2:27 pm |
While trying to overcome my sadness on not being able to make the wheeling trip this weekend I decided to pull out all my junk that l’ve set aside for the front axle upgrade on BSD. Now I just need to find some time between family, school and work to get it started, I’ll probably just shove it all in the corner, wish me luck.
Fri Aug 03, 2018 11:16 am |
Bronco, family, Bronco, school, Bronco and work... You're a BEAST!!!
Fri Aug 03, 2018 11:24 am |
Strike2
[quote="Kinder"]While trying to overcome my sadness on not being able to make the wheeling trip this weekend I decided to pull out all my junk This sounds like the first step to either a great BUILD thread or a really bad XXX movie
Fri Aug 03, 2018 12:47 pm |
colby45
If you need an extra set of hands to get things cranked out, let me know!
Fri Aug 03, 2018 9:16 pm |
Sat Aug 04, 2018 12:21 pm |
colby45
Sat Aug 04, 2018 8:24 pm |
Found a few minutes to tear the D60 down a bit more; hubs, spindles, axles and diff out. New high steer arms with integrated springless kingpin adjustment installed (the stock spring loaded bushing/bearing tension system doesn’t work with big tires) and I also mocked up the tie rod. Next is ARB and gear change, while continuing to massage the C wedges into shape.
Sat Aug 11, 2018 8:08 am |
Strike2
Very nice , every little bit of garage time adds up to compleation
Sun Aug 12, 2018 7:47 am |
Wed Sep 19, 2018 4:50 pm |
Sure makes a great work horse!!
Thu Sep 20, 2018 10:09 am |
Always happy when my mud tires get muddy.
Tue Oct 16, 2018 8:01 am |
What a great setup!! Who's running around on chains?
Tue Oct 16, 2018 9:50 am |
Tue Oct 16, 2018 10:02 am |
rt9
Tue Oct 16, 2018 8:26 pm |
If I never do another D60 ARB install it’ll be too soon, of course I still have the rear axle to do, ha. And how many adapters does it take to go from 1/4” drive to 3/4” drive so I can check the pinion preload? The same number of licks it takes to get to the center of a tootsie pop, three.
Thu Nov 15, 2018 6:43 pm |
Fun!
Fri Nov 16, 2018 9:15 am |
I am about to impart some very vague and uninformed wisdom..........
the O-rings on the ARB in my 9" diff started leaking during our last wheeling trip. leaking so bad the locker wouldn't stay engaged and the compressor stayed running forever and pushed a bunch of oil out of the diff. My ARB probably only have 15k miles on them.
I was talking to Jason about it and he said that Spidertrax had (may still have?) some upgraded o-ring / sealing solution to prevent this.
I haven't had time to look into it further but will be doing so over the winter
probably not critical on the front since carrier isn't always spinning but the rear is another story
Fri Nov 16, 2018 11:44 am |
My O-ring on my rear start leaking in Baja as well. Doesn’t sound as bad as Jeff’s but it was pushing oil up through the solenoid.
I’d be interested in knowing what this upgrade is as I will probably look to fix it later this winter as well.
Fri Nov 16, 2018 11:47 am |
Fri Nov 16, 2018 11:50 am |
Fri Nov 16, 2018 2:28 pm |
Fri Nov 16, 2018 3:33 pm |
Fri Nov 16, 2018 5:29 pm |
Mine have been in for 3 years
When did you install them ?
Fri Nov 16, 2018 6:49 pm |
Mine works great but I just put it in this year. Curious as to what this fix is. Did anyone contact ARB about the issue?
Fri Nov 16, 2018 8:56 pm |
