www.ColoradoClassicBroncos.com - View topic - AIR INTAKE QUESTION
It is currently Fri Nov 22, 2024 6:05 am
Reply to topic  [ 7 posts ]
 AIR INTAKE QUESTION
Post AIR INTAKE QUESTION
I'm using a 96 Explorer EFI set up and have a question on the air intake. I'll be using a K&N cone style filter and was wondering if I need the 2-sensors pointed in red arrows. I believe the top is a air charge temp sensor?? and the bottom is a air flow sensor?? correct me if I'm wrong.
I will also trying to use the upper 90 degree plastic elbow tubing for my conversion.
I had Garry reprogram the computer and used his utube tutorial to rewire the explorer wire harness but that was a year+ ago and need to find where I stashed the re-worked harness lol
Mon Jan 07, 2019 8:55 am
Post Re: AIR INTAKE QUESTION
I think you meant Red arrows?
I can't help ya there, but you might look into the AEM dry-flow universal cone filters. No need for the right oiling to filter the air. And perhaps a good prefilter sock.
Mon Jan 07, 2019 11:20 am
oops, yes red arrows
Defiantly going dry filter, I tried a oil filter on the XJ and hated it as it would clog up really bad in dusty condition. Good point on the pre-filter
Mon Jan 07, 2019 12:03 pm
Airaid makes good filters and pre filter socks. Available on Amazon Prime.
I’m almost certain you need both of those sensors.
Mon Jan 07, 2019 12:26 pm
I do have the air temperature sensor (top red arrow) and I think the only other sensor wired upstream of that is the MAF. And you'll have to utilize a dry filter. The K&N filters with the oil will gum up your MAF sensor.
Mon Jan 07, 2019 12:43 pm
yes. air intake temp and maf.
Mon Jan 07, 2019 12:47 pm
Awesome,
Thank you Gentleman!
Mon Jan 07, 2019 1:16 pm
Users browsing this forum: No registered users and 21 guests
32,943,704 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
