[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 379: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
www.ColoradoClassicBroncos.com - View topic - 74 Baja Race Bronco - Baja or Bust
It is currently Sat Nov 23, 2024 6:17 pm
Reply to topic  [ 309 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 11  Next
Post Re: 74 Baja Race Bronco - Baja or Bust
Looks awesome Chris! it sure was a nice weekend in CO for working this weekend I also took full advantage.
Mon Dec 17, 2018 2:22 pm
A few more things checked off and wiring has started
Wed Jan 16, 2019 11:31 pm
I realize it’s not a rock crawler but I have a set of LED rock lights I am willing to donate to this project.
Let me know.
Thu Jan 17, 2019 12:28 am
Thu Jan 17, 2019 8:29 am
You might need to be working on it at night, so they could come in handy!
This rig is looking sexy!!!
Thu Jan 17, 2019 10:46 am
Doesn’t look like much has been done but we have officially turned the corner on electrical and plumbing. Just missing a few connections for each, electrical is about 95% done and tested. I will go out on a limb and say we are two weeks away from firing it up. Maybe a run around the block.
As always when you fabricate or customize everything we are having to install - tweak - then re-install to get things where we need them. Very time consuming but worth it.
Mon Feb 04, 2019 9:24 am
I am nearly as excited as you are!
Does the spare tire clear the cooling fan ok?
Mon Feb 04, 2019 10:36 am
thumbs up
Amazing work this far Chris!
Mon Feb 04, 2019 10:40 am
Mon Feb 04, 2019 12:42 pm
Your killing it!
Mon Feb 04, 2019 3:58 pm
Looking great!
Almost too nice to race.
Mon Feb 04, 2019 4:16 pm
When is the fire up party ?
Looking great !
Mon Feb 04, 2019 8:11 pm
Mon Feb 04, 2019 11:43 pm
The Bronco is looking Awesome Chris, nice work!
Wed Feb 06, 2019 7:42 am
Post 74 Baja Race Bronco - Baja or Bust
Wed Feb 06, 2019 8:57 am
#35 is ALIVE! Started right up with the help of some fuel priming. Have a few gremlins but overall pretty solid so far. Should be ready to do a lap this weekend and then start buttoning things up for shake down and paint.
Mon Feb 18, 2019 9:32 am
Motor sounds terrific and is rock solid!! congrats on a huge milestone.
Mon Feb 18, 2019 10:08 am
Wow, I'll bet that feels amazing!! Great work! Can't wait to see some laps!
Mon Feb 18, 2019 10:13 am
Nice work Chris!!!!!!
Mon Feb 18, 2019 5:45 pm
Sweet coolant reservoir.
Mon Feb 18, 2019 6:43 pm
That's awesome!
Mon Feb 18, 2019 6:54 pm
Dreams becoming reality !
Mon Feb 18, 2019 8:18 pm
Nice!
Tue Feb 19, 2019 12:26 am
Last major fabrication is done, Front suspension and steering is complete just needs some paint and a few details tidied up to be 100% up front. Somehow we got air bumps stuffed into the motor mounts, they are not at an ideal angle (8-9 degrees off vertical) but for the wheel travel and lift we are running its pretty damn impressive that they fit at all and allow full up travel. i will probably add some shortened poly bumps on the frame as emergency stops as the first thing that would hit if an air bump fails is the trac bar and diff case with oil pan.. Hopefully get the brakes bled this week and take a run around the block before the next round of snow hits. 60 days left!!!!
Mon Feb 25, 2019 11:34 am
Looking sick!
Mon Feb 25, 2019 4:13 pm
Great progress guys, keep up the momentum.
Mon Feb 25, 2019 7:35 pm
60 days??? Wow! Do you know if there will be any streaming support for this event? I would love to try and watch or even just listen in.
Tue Feb 26, 2019 10:57 am
Tue Feb 26, 2019 11:12 am
45 days.
It’s now out of paint and back home for “final” assembly.
Paint teaser :)
Tue Mar 12, 2019 5:40 pm
Hmmmmmm.....
Tue Mar 12, 2019 6:23 pm
32,979,871 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
