It is currently Fri Nov 22, 2024 6:22 am
[ 10 posts ] |
B.O.B.
Truck died
Dropped my son off this morning and won’t start back up. Started fine and drove about a mile to his school and shut it off to go inside. Came out and won’t turn over. I can smell the fuel and can hear the fuel pump working. Must be something with spark. I am at work now and just getting some opinion on what to check.
Start with: Check for spark- coil, distributor Check fuses. What else?
91 mustang efi on original short block
Thu Mar 21, 2019 7:29 am |
Re: Truck died
Does it just click when you try to start it? fuel pump primes and then click? Is it an auto or manual?
Thu Mar 21, 2019 1:04 pm |
B.O.B.
Re: Truck died
Manual, it cranks just won’t catch and turnover
Thu Mar 21, 2019 1:57 pm |
Truck died
Thu Mar 21, 2019 2:09 pm |
B.O.B.
Re: Truck died
Just got back to it and it started. I don’t know if I should be happy or mad. I’ll just get it home and take a look at some things. Maybe fuel pressure regulator went out and flooding cylinders or something.
Thu Mar 21, 2019 2:20 pm |
Re: Truck died
I had an ignition coil do that to me once. Happened twice then I had the tools on hand to diagnose it when it happened the 3rd time. Replaced it on the side of the road and it's been flawless since.
Thu Mar 21, 2019 4:13 pm |
B.O.B.
Re: Truck died
I probably should replace it. Got it out of a salvage yard years ago not to mention the car I took it off of was pretty old also.
Thu Mar 21, 2019 8:07 pm |
Re: Truck died
Ford electronic ignition? the "brain box" can do the same when they get old. along with a coil. they'll work when cold but once they get warm they die.
Fri Mar 22, 2019 6:14 am |
Re: Truck died
It's a good idea to keep a complete, spare distributor on board with the mustang EFI. Spare coil is good too.
Fri Mar 22, 2019 9:25 pm |
cw72
Joined: Sun Jul 08, 2018 9:04 am Posts: 113 Location: Denver, CO
Re: Truck died
My bet is the TFI. Mounted on the side of the distributor. When it gets hot it can act screwy. Happens to me every once in a while when I run it hard mostly. I’m running a 90 efi mustang motor as well.
Fri Mar 22, 2019 10:27 pm |
[ 10 posts ] |
Users browsing this forum: No registered users and 21 guests |
