www.ColoradoClassicBroncos.com - View topic - Truck died
It is currently Mon Nov 25, 2024 12:16 pm
Reply to topic  [ 10 posts ]
 Truck died
Post Truck died
Dropped my son off this morning and won’t start back up. Started fine and drove about a mile to his school and shut it off to go inside. Came out and won’t turn over. I can smell the fuel and can hear the fuel pump working. Must be something with spark. I am at work now and just getting some opinion on what to check.
Start with:
Check for spark- coil, distributor
Check fuses. What else?
91 mustang efi on original short block
Thu Mar 21, 2019 7:29 am
Post Re: Truck died
Does it just click when you try to start it? fuel pump primes and then click? Is it an auto or manual?
Thu Mar 21, 2019 1:04 pm
Post Re: Truck died
Manual, it cranks just won’t catch and turnover
Thu Mar 21, 2019 1:57 pm
Post Truck died
Thu Mar 21, 2019 2:09 pm
Post Re: Truck died
Just got back to it and it started. I don’t know if I should be happy or mad. I’ll just get it home and take a look at some things. Maybe fuel pressure regulator went out and flooding cylinders or something.
Thu Mar 21, 2019 2:20 pm
Post Re: Truck died
I had an ignition coil do that to me once. Happened twice then I had the tools on hand to diagnose it when it happened the 3rd time. Replaced it on the side of the road and it's been flawless since.
Thu Mar 21, 2019 4:13 pm
Post Re: Truck died
I probably should replace it. Got it out of a salvage yard years ago not to mention the car I took it off of was pretty old also.
Thu Mar 21, 2019 8:07 pm
Post Re: Truck died
Ford electronic ignition? the "brain box" can do the same when they get old. along with a coil. they'll work when cold but once they get warm they die.
Fri Mar 22, 2019 6:14 am
Post Re: Truck died
It's a good idea to keep a complete, spare distributor on board with the mustang EFI. Spare coil is good too.
Fri Mar 22, 2019 9:25 pm
Post Re: Truck died
My bet is the TFI. Mounted on the side of the distributor. When it gets hot it can act screwy. Happens to me every once in a while when I run it hard mostly. I’m running a 90 efi mustang motor as well.
Fri Mar 22, 2019 10:27 pm
33,041,784 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
