It is currently Fri Nov 22, 2024 6:07 am
[ 10 posts ] |
Looking to buy a crate 302 for my 69
n8diz
Joined: Mon Nov 26, 2018 12:36 pm Posts: 2 Location: Thornton
Hey guys, I am looking to buy a crate 302 for my '69. I have been looking online but I am pretty green to buying a motor and honestly not to sure what I really need. This will be a daily driver for my wife so I don't want to spend an arm and a leg if i don't need to. Any suggestions?
Mon Mar 25, 2019 10:59 am |
Re: Looking to buy a crate 302 for my 69
Look at blueprint. They build a bronco specific 302
Mon Mar 25, 2019 7:41 pm |
pgilbeau
Mon Mar 25, 2019 7:44 pm |
RJLougee
Personally, and I know it's not the original question, but I never, ever, recommend a 302 to anyone who needs to repower their Bronco. The 351W is just a much better engine in an EB.
Yes, I run a 5.0 in one rig, but it weighs 2700#, not 4700# like most trail rig EBs.
Yes, it can be a bit more expensive for some specific builds; however, totally worth it. With a carb or FITECH setup, pretty much even cost.
As for where to get one, assuming you're doing the labor, Blueprint, Jasper, ATK, etc... are all good choices. Summit Racing is a major vendor who sells many of those.
And there are several local vendors who build quality engines, can't tell where you are from your sig. HTH, Joe
Mon Mar 25, 2019 8:11 pm |
I would 2nd going with a 351W. Not only a bigger, torquey'r engine, it has bigger bearings, rods, etc. It can run at higher power levels for longer without failure.
Tue Mar 26, 2019 7:34 pm |
n8diz
Thanks guys. I'll keep you posted
Wed Mar 27, 2019 4:59 am |
Stubborn3
Joined: Mon Sep 17, 2012 3:09 am Posts: 174 Location: Denver/Leadville, Coloradical
With all the install support do a 351w. I have a great 351c but it’s big in weird places and is more work for the same gain I’d assume
_________________ '72 sport, 351 Cleveland, NP435, twin-sticked 20, unknown lift- if any, 35" KM2s siped by B.O.B, custom rust and dents, 2 kid seats.
Tue Apr 02, 2019 1:15 pm |
Tue Apr 02, 2019 2:23 pm |
RondaTheBronco
I am in a similar boat, but mine is a '77 and subject to smog inspections. So I am guessing my best bet to get some power, and still pass the visual test is to get a blueprint 302 with EFI and keep the smog pump and other components. Anyone recommend a shop that could a swap like this in the Louisville area?
Thanks
_________________ 1977 Ford Bronco Ranger, 302 EFI, Disk Brakes, cut fenders, 32" MTs, and all stock interior.
Thu Apr 18, 2019 8:57 pm |
Fri Apr 19, 2019 6:15 pm |
[ 10 posts ] |
Users browsing this forum: No registered users and 21 guests |
