Register •
FAQ
• Login
It is currently Fri Nov 22, 2024 5:10 am
[ 4 posts ] |
Anyone in Aurora area know how to die/tap a new thread?
laffycaffi
I have two bolts that snapped supporting my transmission cross member. I've tried penetration oil and an extraction bit and also torching it out. Neither worked. I got the bolt free just from drilling through. But now I have no threads and a bigger hole. Figured I'd seek help before I really screw it up.
Anyone out there who knows how to do this?
Sat May 25, 2019 8:14 am |
Re: Anyone in Aurora area know how to die/tap a new thread?
Go get a tap set from Harbor Freight and you would tap it by hand slowly and careful to keep it straight. It’s not complicated at all.
Sat May 25, 2019 2:27 pm |
cpldavis37
If you can weld a nut to the bolt you can just turn it out. Its the easiest way I have found to get a snapped bolt out.
Tue May 28, 2019 11:19 am |
laffycaffi
Got it. Thanks B.O.B. for letting me borrow your kit. Easier than expected.
Sent from my SM-N950U using Tapatalk
Wed Jun 05, 2019 7:13 am |
[ 4 posts ] |
