www.ColoradoClassicBroncos.com - View topic - Cam's 73'
It is currently Thu Nov 21, 2024 4:30 am
Reply to topic  [ 131 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Cam's 73'
Post Cam's 73'
Hey there, my name's Cam, my dad just bought a 73' bronco with a 302, 3 speed standard transmission for me and my 2 brothers, I'm 15 and this is my dads 8th bronco but I've helped him fix up the last 7 (including this one) and it doesnt look like it's in too great of shape at the moment, but we have a replacement hood, power steering gear, power brake booster, and grille already but are waiting on a fender, doors and seats but we also have a soft top ready to go on. We plan on adding the power steering, maybe power brakes, and maybe a little 3" lift. The motor looks to be in great shape, but we will be replacing the points, cap, spark plug wires and the plugs themselves. A carburetor will soon be installed, and the brakes will all be re-done. Today I had taken off the rear bumper, hitch and disconnected the main gas tank to it can be cleaned and we can replace all of the fuel lines necessary. Theres quite a bit of work to be done but at the same time theres not a lot of work at all.[img][img][/img][/img]
Mon Jul 15, 2019 8:37 pm
Post Re: Cam's 73'
Congratulations Cam! Sound like this isn’t your rodeo around Bronco’s
I’m looking forward to the build thread thumbs up
Mon Jul 15, 2019 9:13 pm
Post Re: Cam's 73'
Great job Cam, keep up the good work little buddy I can’t wait to see what you do with this one!
We’ll work on getting your pictures straight later!!! LOL!!!
Cam is the one standing.
Tue Jul 16, 2019 7:49 am
Post Re: Cam's 73'
What a great project and the knowledge you boys are gaining will benefit you for your entire life. It will also benefit your eventual family!!
BTW - do you know any back story on this ole girl?
Thu Jul 18, 2019 2:43 pm
Post Re: Cam's 73'
1973; 302; Mexican Block; Standard 3speed; lifted; 33's; Slotted mags; Bilsteins; Stroppe; Dana 44; Power Brakes; Power Steering; Cut; Retrosound
Fri Jul 19, 2019 9:20 pm
Post Re: Cam's 73'
I am just glad it's getting a second chance with you!
Sat Jul 20, 2019 5:45 am
Post Re: Cam's 73'
Wheels/Tires are from Kirk and BSD!
Making the loop this Sunday to hit Crawler creations for fender flares,
Then Picking up a fender from Terry D,
And then a buddy of BroncoJanes has a good pair of doors and hood we’re getting!
We’re going to try and straighten out the top corner of the grill and make that work but it should look like a Real Bronco in another week or so!
Sat Jul 20, 2019 7:23 am
Post Re: Cam's 73'
Thanks to crawlercreations for the flares!
Sun Jul 21, 2019 10:05 am
Post Re: Cam's 73'
Thank you Tim and Buddy for my New seats!
Thank you Terry D for my fender, dash pad, windshield and miscellaneous Bronco parts!
Thank you Brian for my doors and my hood!
Thank you Jay H. For my window frame and Dana 30 parts front end!
I'm already working hard to disassemble the bad and to reassemble good!!!
Sun Jul 21, 2019 9:11 pm
Post Re: Cam's 73'
Just dropped the Auxiliary tank, its cracked and leaks so we'll need to find a replacement.
Mon Jul 22, 2019 11:32 am
Post Re: Cam's 73'
Mon Jul 22, 2019 1:24 pm
Profile WWW
Post Re: Cam's 73'
Just took a spot weld drill bit and drilled out all the spot welds for the old windshield frame and we're about ready to weld the new one in. It wasnt easy!
Mon Jul 22, 2019 2:32 pm
Post Re: Cam's 73'
Drilled out all the rivets for the old flares, ready to buy a rivet kit and paint the new flares
Tue Jul 23, 2019 3:01 pm
Post Re: Cam's 73'
Beat the snot out of the grill, fitted the new fender!
Thu Jul 25, 2019 11:21 pm
Post Re: Cam's 73'
Grill came out better than what I would have expected!
Fri Jul 26, 2019 5:24 am
Post Re: Cam's 73'
More progress...
Next to even out the front a little bit and do the Brakes and They’re going to be in business!!!
( oh yeah, and then there’s those seats and that windshield thing )
Thu Aug 01, 2019 7:13 am
Post Re: Cam's 73'
Man your making great progress! Looking good thumbs up
Thu Aug 01, 2019 8:13 pm
Post Re: Cam's 73'
Front Coils in!
Pertronix ignition in!
Brakes next....
Sat Aug 03, 2019 3:23 pm
Post Re: Cam's 73'
Clearly I have a problem
Tue Aug 06, 2019 8:54 pm
Post Re: Cam's 73'
Got the new top on today and some new shocks ready to be installed!
Sat Aug 24, 2019 2:11 pm
Post Re: Cam's 73'
Got all of the steering hooked up, and ready for the power steering pump. Got the fan pulley and the one underneath it swapped for dual pulleys for power steering. Also got the power brake booster installed and just need the lines from the master cylinder down to the connection on the frame (forget what it's called). We put a different hood on as well which will hopefully get painted black eventually and got the windshield frame set in place which we'd like to get welded in here soon whether someone can do it for us or we can get a 220 outlet installed in the garage. Before we do our welding, I believe I'll try and drain the oil (as it smells like gas so we replaced the fuel pump as well) add belts, the power steering pump and radiator fluid (most likely just water for now) and hopefully see if she'll start!
Sun Oct 06, 2019 10:35 am
Post Re: Cam's 73'
That's quick work!! Congrats on the progress looks awesome thumbs up
Mon Oct 07, 2019 9:00 am
Post Re: Cam's 73'
Just got the 1" lift blocks installed in the back, I didn't snap any pics yet. You can't see mich of a difference other than the fact it leveled it out more than it was after lifting the front end 2.5" power steering pump should get here Monday and soon after that's done and a few other little loose ends, we'll see if she'll start!
Sat Oct 12, 2019 7:15 pm
Post Re: Cam's 73'
Also got the brake lines ran from the master cylinder to the connector on the frame (still not sure of the name)
Sat Oct 12, 2019 7:28 pm
Post Re: Cam's 73'
Sat Oct 12, 2019 7:59 pm
Post Re: Cam's 73'
Sun Oct 13, 2019 2:24 pm
Post Re: Cam's 73'
Got the drop pitman arm installed as well as the drop track bar bracket installed, Axle centered up amazing. Also got the power steering pump and reservoir separated to paint the outside of the reservoir and then make it with the new pump as soon as it gets here!
Sun Oct 13, 2019 2:27 pm
Images: 11
Post Re: Cam's 73'
You are doing a great job!
Mon Oct 14, 2019 8:10 pm
Post Re: Cam's 73'
Got the power steering pump installed, ready for belts and hoses
Sat Oct 19, 2019 2:13 pm
Post Re: Cam's 73'
Got a few things done, got the windshield frame welded kn as well as the uncut hood hinges so I got those put on, as well as a lower profile air filter to fit under the hood, got started with the oil change by draining it then adding 5qts of fresh oil, and then filled the radiator with antifreeze and water 50/50 mix. Wasn't as big of a deal as the rest but we put on a car cover to try and keep some of the rain and snow out. Got some help from my buddy Caden. Couple more things to fill with fluids and then a seat and might be able to fire it up!
Sun Nov 03, 2019 7:58 pm
32,908,229 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
