It is currently Sat Nov 23, 2024 6:18 pm
[ 9 posts ] |
bronco parts need gone cheap
welderlen
these are some of my pieces to get gone, im in Littleton
1 pass front seat brown, fairly good shape not all torn up 50$
1 rear gas tak door 10$ 2 rear side panels brown good shape 30$ 1 rear gas tank skid plate 3 straps 3 filler tube
1 hood 1 has a large center hole cut in it,you can see the cutout was for a hood scope. summit probally has the scope. 40$ 2 door panels brand new aluim diamond plate still in box never instaled 20$ 2 doors have window frames cut off , handles removed (rocks ate em) both have been shaved on the bottom just below the lower hinge. 3.5 " above stock, have accuators missing 20$
4 rear side glass 5$ 1 rear hatch glass 5$ 1 set of rear hatch arms 5$ 1 1 inner heater box 5$ 2 visors 5$ 1 upper wipper motor cover 5$ 2 bronco sport frt. nameplates `15$
Ill try to post some pics
more to come as i find it, im in littleton call or text 720 934 0806 Im not very device user able if you call 303 794 6001 its easy for me
Thu Sep 19, 2019 12:57 pm |
Re: body parts
Would you happen to have a good set of glove box door hinges ?
Thu Sep 19, 2019 1:22 pm |
welderlen
Re: body parts
sure do, they are on the dash, has ash tray, also all the control knobs
Thu Sep 19, 2019 2:26 pm |
Strike2
Re: body parts
I would be interested in the doors I will sent you a text.
Thu Sep 19, 2019 2:42 pm |
Strike2
Re: body parts
Thanks for the call Welderlen!
I’m going to pass on the doors for the moment, and see if anyone needs them for a build. My plans are to use a cutoff wheel and make lots of sparks!
Thu Sep 19, 2019 3:09 pm |
welderlen
Re: body parts
I just pulled the doors out. they have been shaved on the bottom about 3.5" up . right below the lower hinge.-- len
Thu Sep 19, 2019 3:22 pm |
welderlen
Re: bronco parts need gone cheap
I just found a glove box door and hinges,tagged as a 76
Sun Sep 22, 2019 7:52 pm |
Thanks for the offers........I broke out the welder and unscrewed up my hinges
Tue Sep 24, 2019 2:48 am |
Evolkid
Joined: Fri May 31, 2019 6:04 pm Posts: 4 Location: Timnath, CO
Got a pic of the hood without the cutout?
Tue Sep 24, 2019 6:04 am |
[ 9 posts ] |
