www.ColoradoClassicBroncos.com - View topic - Need wiring help!
It is currently Fri Nov 22, 2024 6:35 am
Reply to topic  [ 7 posts ]
 Need wiring help!
Post Need wiring help!
I’m connecting my 79 tilt automatic steering column to my 68 Bronco.
This is what I have so far and I think it’s almost correct but not sure about 100%
On the Left is the column wiring connected to the Right 68 wires...
2 prong connector
Green/Orange stripe To Orange/Green stripe
Orange/White stripe To Orange/Blue
6 prong connector
White/Blue stripe To White/Blue stripe
Green/White stripe To Light Green/White stripe
Blue To Blue/Yellow stripe
Green To Yellow
Yellow/White stripe To Green
Light Blue To Light Blue
*White with red stripe Unattached
ThankYou!!!
Filling up engine fluids and going to start it today for the first time since motor and trans have been dropped in!!!
Sun Sep 29, 2019 10:24 am
Post Re: Need wiring help!
Front Lt & Rt turn signals work
Rear Driver side tail light is ON... no blink on the driver side and no blink on the passenger side, it’s just on and even when you turn the key off it’s on !!!
I disconnected one of the wires on the two prong unit and got it to go off but still working out bugs
Sun Sep 29, 2019 8:11 pm
Take a pic of the wires on the harness side and on the turn signal switch side and I should be able to get you straightened out.
Mon Sep 30, 2019 1:44 pm
ThankYou Phil...
(please don’t Pass Out when you see my wiring skills ... or lack there of!!!)
Mon Sep 30, 2019 9:52 pm
Ok. First thing I notice is there are not enough wires. Should be 10 wires in the tilt column. Also some colors don't match my info. This should get you close.
68 Bronco to 79 truck tilt auto column
green-orange (left rear brake and turn lamp, circuit #9)=green-orange or yellow-black
orange-blue (right rear brake and turn lamp, circuit #5)=green or orange-blue
white-blue (right front turn and indicator lamp, circuit #2)=white-blue
green-white (left front turn and indicator lamp, circuit #3)=green-white
blue-yellow (horn switch to horn, circuit #482)=blue-yellow or dark blue
yellow (12v headlight switch to horn switch, circuit #460)=yellow-blue or yellow
green (12v brake switch to turn signal switch, circuit #810)=red-black or green
light blue (12v from turn flasher to turn switch, circuit #44)=light blue
You'll need to add these wires if you want them.
dash light wire=light blue-red (for column shift indicator light)
pulsed 12V from hazard flasher=white-red (if you want to add hazard switch on column)
Wed Oct 02, 2019 1:52 am
Can't thank you enough!!!!!!!!!!!!!!!!!!!!!!!
...ThankYOU!
Hopefully get some time this weekend to check it out.
Wed Oct 02, 2019 10:49 am
PHIL!!!!
YOU ARE THE MAN!!! ( but we all knew that already ;)
Three out of the four corners work perfectly, the rear passenger doesn’t do anything, I think there’s a cut wire somewhere between the light and the T? But I changed three of my wires and did what you said and everything works perfect man thank you so much!!!
Now onto my transmission woes...
Fri Oct 04, 2019 9:39 pm
Users browsing this forum: No registered users and 25 guests
32,944,621 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
