www.ColoradoClassicBroncos.com - View topic - Cam's 73'
It is currently Tue Dec 03, 2024 11:12 am
Reply to topic  [ 131 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Cam's 73'
Post Re: Cam's 73'
The best thing I saw all weekend...
Mon Nov 04, 2019 5:27 pm
Post Re: Cam's 73'
Thanks to Terry for thinkin of us while he was down on vacation in Florda, he picked up these flares for me! They look sweet and they feel way more durable than the fiberglass ones I was going to use. They fit other than the one spot with the aux tank filler neck but we made it work!
1973; 302; Mexican Block; Standard 3speed; lifted; 33's; Slotted mags; Bilsteins; Stroppe; Dana 44; Power Brakes; Power Steering; Cut; Retrosound
Sun Jan 05, 2020 9:56 pm
Post Re: Cam's 73'
Looks great!!
Mon Jan 06, 2020 8:28 am
Post Re: Cam's 73'
Looks way better with the rear flares on. thumbs up
Mon Jan 06, 2020 12:15 pm
Post Re: Cam's 73'
Cam put in some good work this weekend even though it was cold. He got to wire wheel the BED LINER GARBAGE off of front windshield frame before priming and painting it Black like the hood, and then we put the new windshield into the gasket and mounted it up on Sunday!
He’s going to remove the hardtop and hopefully get the old white Kaline soft top mounted up next weekend!
So proud of this Kid!
Sun Jan 12, 2020 10:38 pm
Post Re: Cam's 73'
That’s coming together nicely !
Mon Jan 13, 2020 7:04 am
Post Re: Cam's 73'
Love it!! He seems to be taking his time and doing a great job. Wish I would have learned patience when I was at that age!
Mon Jan 13, 2020 10:19 am
Post Re: Cam's 73'
Lookin’ good!
Mon Jan 13, 2020 9:42 pm
Post Re: Cam's 73'
Wow you guys are making great progress in a short amount of time. The bronco is looking great!
Mon Jan 13, 2020 10:07 pm
Post Re: Cam's 73'
So, its definitely been awhile since I've posted, but progress is still being made despite the weather. I threw in some bilsteins in the rear but I have some duffs on the way because the bilsteins are just a bit too big. I also got the rear half of the brakes taken out and replaced so we'll be able to bleed them soon. I forgot to take a picture but I put in the new glovebox as well.
Mon Feb 24, 2020 7:45 pm
Post Re: Cam's 73'
Way to keep at it. Brakes are important!
Mon Feb 24, 2020 8:11 pm
Post Re: Cam's 73'
What are the collapsed and extended measurements on the Bilsteins? I may be interested in them when you swap them out.
Mon Feb 24, 2020 8:14 pm
Post Re: Cam's 73'
Tue Feb 25, 2020 10:54 am
Post Re: Cam's 73'
Tue Feb 25, 2020 5:03 pm
Post Re: Cam's 73'
Tue Feb 25, 2020 9:52 pm
Post Re: Cam's 73'
Got this old POS tidied up!
Wimbledon white
Tue Mar 24, 2020 4:42 pm
Post Re: Cam's 73'
Huh. Well how bout that?
Fri Mar 27, 2020 2:17 pm
Post Re: Cam's 73'
Love that idea. I wonder if you will have to port the boxes for better sound?? If they are sealed then the speakers will be creating a vacuum and then pressure. You might need a small hole somewhere.
Fri Mar 27, 2020 8:56 pm
Post Re: Cam's 73'
Sat Mar 28, 2020 12:08 pm
Post Re: Cam's 73'
Still doesnt solve the problem tho. Perhaps it doesnt matter with 6x9 but that is why the ported subwoofer boxes work best.
Sat Mar 28, 2020 3:52 pm
Post Re: Cam's 73'
Yeah probably not for a 6x9 I had a couple small boxes on my wheel wells w/6x9s, with no port. Probably not as sealed as an ammo can though.
Sat Mar 28, 2020 6:55 pm
Post Re: Cam's 73'
Cam’s Room... Eat, Sleep, Bronco, repeat!
Thu Apr 02, 2020 6:19 pm
Post Re: Cam's 73'
Soooo, we got everything down to the timing, about to get a new timing chain, gaskets, oil pan and the rest of the front of the motor put in, a new driver side wing window and this sweet new steering wheel
Fri Apr 17, 2020 6:10 pm
Post Re: Cam's 73'
So we got a few things done over the weekend, painted the fender flares, got the timing chain, timing chain cover gasket, oil pan gasket, got the oil pan painted, got all that reinstalled, new fuel pump gasket, new headlights installed, cut out the passenger side floor pan, decided on a "new" rear bumper (which is actually off of my dads first ever bronco) but now we need a new power steering pump because our new one pooped out on us before we even used it then we should be good to go on some more goodies!
Mon Apr 20, 2020 8:12 pm
Post Re: Cam's 73'
Do you want to upgrade to the Saginaw pump? I believe I have the complete setup w/ brackets for a Bronco sitting in storage, it may even be a dual return.
Tue Apr 21, 2020 10:10 am
Post Re: Cam's 73'
Thu Apr 23, 2020 6:17 am
Post Re: Cam's 73'
Cam did a great job cutting out the rust, just need a couple thin patch panels and drop the front in place and we’ll be halfway done!
Thu Apr 23, 2020 6:35 am
Post Re: Cam's 73'
Nice work on the spot welds thumbs up
Thu Apr 23, 2020 8:16 pm
Post Re: Cam's 73'
Does he want to come do that on mine?
Thu Apr 23, 2020 9:32 pm
Post Re: Cam's 73'
Got the old tailgate gutted and put everything into the new one, it still doesn’t fit right with the bedsides a little bent outward so we’ll definitely find a way to straighten that out to make the tailgate latch correctly
Sun May 03, 2020 12:00 am
33,206,282 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
