It is currently Sat Oct 12, 2024 4:17 am
[ 14 posts ] |
Strike2
EGR delete on 96 EFI
I just saw a posting on CB about plugging the EGR port on the intake, I didn't do anything to mine (but only have 30+min of brake in time) Is this something I should be concerned about ? ?
Fri Jan 31, 2020 3:09 pm |
Moab Mike
Re: EGR delete on 96 EFI
Yes, If you are not using EGR you should plug the port. I believe I used a 3/4" or 1" NPT Pipe tap which creates enough thread to thread a brass pipe plug with an allen head into either the intake or the head. I chose the head because I already had the engine in the bay already and wanted it to be easy to clean out.
Fri Jan 31, 2020 8:29 pm |
Strike2
Dang that’s not good news, looks like I’ll add that to my list!
Thanks for the reply Moab Mike
Fri Jan 31, 2020 8:59 pm |
D&D72
You can put it in the upper half too without issue since you lower appears to be installed.
Sat Feb 01, 2020 10:50 am |
Strike2
Sat Feb 01, 2020 8:42 pm |
I was looking into this last year when I was considering doing EFI and found this ...fel pro 1250 intake gasket set has parts that block the EGR crossover at the cylinder head/intake manifold gasket. This is the best spot to block off the EGR gasses so that they do not enter the intake manifold and heat it up. Just install the gasket and no tapping drilling etc.
Sun Feb 02, 2020 8:39 am |
I tapped mine without pulling the lower intake off the engine, You can carefully put a rag or something that won't tear apart in the hole, tap it carefully and then vacuum it out. It worked great for mine and had no issues or metal shavings
Sun Feb 02, 2020 10:15 pm |
Strike2
Wed Feb 05, 2020 12:49 pm |
I just looked back at what I did. I tapped the upper intake with a 7/8-9 tap. I don't know what the lower intake would use.
Wed Feb 05, 2020 1:57 pm |
Strike2
Wed Feb 05, 2020 3:28 pm |
Yes, then I cut a bolt off, threaded it in. It was loose and I was wanted to make sure it didn't move, so I think I staked it in place. Maybe some red lock-tite would have worked. I forget exactly what I did.
Wed Feb 05, 2020 3:32 pm |
Strike2
Wed Feb 05, 2020 3:46 pm |
Sorry just getting back. I am not sure but want to say 1/2 NPT? I could be wrong -
Mon Feb 10, 2020 1:53 pm |
Strike2
NP Chris, I'm pretty sure a 1/2-14 NPT tap would work on the lower, but on the upper there just isn't enough depth to work. And since the lower is already installed and it running I didn't feel like taking the "risking" this late in the build. I use a 7/8-9 tap like Gunnibronco recommended on the upper and it work great!
Mon Feb 10, 2020 4:14 pm |
[ 14 posts ] |
