www.ColoradoClassicBroncos.com - View topic - TJ's 74 Bronco money pit
It is currently Sat Nov 23, 2024 1:56 am
Reply to topic  [ 259 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9
Post Re: TJ's 74 Bronco money pit
It’s been a long road, very happy you have it to a level you like it. I think it looks great.
Fri Jun 21, 2019 3:26 pm
I installed an on board air setup. It cost about 250 in total, so half the price of the ARB compressor I was considering.
TJ
F. Scott Fitzgerald
Mon Nov 18, 2019 5:26 pm
I ordered it in July and I finally got it. It was worth the wait. Thank you BC Broncos.
The top goes together easy enough, but getting the snaps on is a son of a gun.
TJ
F. Scott Fitzgerald
Mon Feb 24, 2020 2:00 am
I really like the Look of those!
Mon Feb 24, 2020 10:43 am
Mon Feb 24, 2020 11:51 am
Thanks for the info, I'll order some.
TJ
F. Scott Fitzgerald
Mon Feb 24, 2020 12:16 pm
I also found - and it will depend on your top and the fit - that using a door panel clip removal tool is nice as it makes the snaps last longer and pops them right off. I happened to have one from other projects and found it useful :)
https://www.amazon.com/Cal-Hawk-Door-Pa ... 336&sr=8-1
Mon Feb 24, 2020 12:53 pm
Good idea!
TJ
F. Scott Fitzgerald
Mon Feb 24, 2020 3:07 pm
NASCAR Mike, does he still go by that nick?, had some different style canvas attachment snaps on his locally made 1/2 cab soft top, something like this. They seemed to work well in the cold and looked like they’d hold up a bit better over time.
Mon Feb 24, 2020 8:20 pm
Top looks great!!
Having had tonneau covers on all my trucks, I knew to avoid snaps and velcro. There was two options that would work here assuming that there is some sort of channel mounted to the bedsides? This cover had an extruded aluminum channel that mounted to the bed. Then the cover had an extruded plastic hook attached to the fabric. This was great as there were no snaps and no velcro.
Here is the basic concept for this tonneau. It would have to be rolled 90 with the channel facing down to work for a bronco top.
Tue Feb 25, 2020 9:14 am
Tue Feb 25, 2020 10:24 am
Tue Feb 25, 2020 10:27 am
What tightens the fabric? Perhaps I don't understand the install. If my assumptions are correct, this style of fastening wouldn't be any different than the snaps.
Tue Feb 25, 2020 10:36 am
It is tight to begin with you pull it and snap it. Once the top is installed it has 2 turnbuckles on the rear bar that you can tighten when needed.
TJ
F. Scott Fitzgerald
Fri Feb 28, 2020 2:57 pm
I snapped a front axle shaft this weekend. On a good note it was a stock shaft and I have been wanting an upgrade for years. I ordered the TBP "Trail Terminator" front axle shafts. The website advertises 60% stronger than stock. We shall see.
TJ
F. Scott Fitzgerald
Wed Mar 17, 2021 2:04 pm
Oops I broke both sides at one time. lol
TJ
F. Scott Fitzgerald
Thu Mar 18, 2021 4:02 pm
Um, that may mean that you need to ease up on the skinny pedal!
Fri Mar 19, 2021 5:49 pm
That's just so difficult.
TJ
F. Scott Fitzgerald
Fri Mar 19, 2021 6:27 pm
LOL! It is at times, but I know my wallet dictates how much throttle is applied after a few sets of u-joints and shafts!
Mon Mar 22, 2021 8:22 am
32,964,256 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
