It is currently Thu Nov 21, 2024 9:15 am
[ 16 posts ] |
ManTruck
ZF5 Transmission
Looking for the ZF 5 transmission from the small block 4X4 donor. Anyone have one available.
Thanks Dave
_________________ Owned my 1972 since 1985
Canon City, Co
Tue Apr 07, 2020 10:19 am |
JGZ
Re: ZF5 Transmission
I don't have the trans,But I do have the AA adapter. New in box.And you're right up the street..
Tue Apr 07, 2020 1:00 pm |
ManTruck
FYI i need it to bolt to a small block with an atlas 2sp coming off of the rear. I wont have the Dana 20 bolted to it.
Canon City, Co
Wed Apr 08, 2020 1:33 pm |
ManTruck
Thanks JGZ, how much for the adapter. You can PM me if you like
Canon City, Co
Wed Apr 08, 2020 1:35 pm |
I think the ZF bolts directly to the Atlas, but needs a spacer (it does to the 4 speed Atlas). I have a 1" spacer that I didn't use. I went to a 1/2" spacer just to get as much space as possible due to the length of the 4 speed. If you want the 1" spacer let me know. It's been mocked up but never run, minor scratches from test fitting.
Wed Apr 08, 2020 1:40 pm |
ManTruck
Thanks for the input and info. I will get my tranny first then cross the adapter bridge as well.
Canon City, Co
Wed Apr 08, 2020 2:06 pm |
Yes, the ZF5 does bolt straight to the Atlas. It does require a spacer, but I went the simple route and shortened the output shaft by 1/2".
Thu Apr 09, 2020 9:32 am |
Thu Apr 09, 2020 9:41 am |
ManTruck
I believe that was a good move on your part by not forcing it. What vehicle did the transmission come from.
Canon City, Co
Thu Apr 09, 2020 10:10 am |
I'm not exactly sure what it came from bought it from Craigslist ad. It has a 1989 date code if I remember. From what I've read most came in F250s, but some were in F150s.
I have another ZF I found since but haven't test fit or measured the output shaft/splines to compare. I don't remember the date code from that one.
Thu Apr 09, 2020 10:39 am |
pgilbeau
As best I know late 80's to mid 90's F250 that had a 351W, my master cylinder is from a '95 F250. I will take a look and see if I can find my info from when I did the swap. I would be careful with the F150, thought they came with a M50D.
Fri Apr 10, 2020 1:05 pm |
Just look at the tag on the driver's side of the transmission. It will have a ZF and Ford logo and right below that, a P/N. You want the S5-42 or S5-47
Fri Apr 10, 2020 4:24 pm |
Fri Apr 10, 2020 7:04 pm |
ZF5 Transmission
Fri Apr 10, 2020 7:33 pm |
Fri Apr 10, 2020 8:44 pm |
Ah ok nice to know!
Sat Apr 11, 2020 12:28 am |
[ 16 posts ] |
