www.ColoradoClassicBroncos.com - View topic - TFB SITREP
It is currently Thu Nov 21, 2024 4:36 am
Reply to topic  [ 215 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
 TFB SITREP
Post Re: Big O
Nice
Fri Feb 02, 2018 8:25 am
Post Re: Big O
That's real nice, Clark.
Fri Feb 02, 2018 8:43 am
Post Re: Big O
So, where are the promised pictures....?
Fri Feb 02, 2018 9:50 am
Post Re: Big O
Demanding audience! We still have a lot to do, including bolting the rocker guards back on to cover up the beat on rockers
Fri Feb 02, 2018 6:07 pm
Post Re: Big O
Just curious- did you reshoot the whole thing? What was going on with it?
Fri Feb 02, 2018 6:53 pm
Post Re: Big O
Let’s see the rear fender handiwork.
Fri Feb 02, 2018 7:43 pm
Post Re: Big O
Greatness.
Fri Feb 02, 2018 9:18 pm
Post Big O
Fri Feb 02, 2018 9:33 pm
Post Re: Big O
Fri Feb 02, 2018 9:34 pm
Post Re: Big O
Enjoy Willem! Thank you both for Your patients....and not dying on you!!
Still a bit to do, but Boulder be ware!!
Fri Feb 02, 2018 9:42 pm
Post Re: Big O
Sat Feb 03, 2018 10:14 am
Post Re: Big O
Big O looks real nice! W is going to have a lot of fun scooting around the People's Republic.
Wed Feb 07, 2018 9:19 am
Post Re: Big O
Declan made this console cover for Willem’s bronco, it turned out great.
Sun Apr 08, 2018 3:23 pm
Post Re: Big O
Sun Apr 08, 2018 3:31 pm
Post Re: Big O
Mon Apr 09, 2018 11:02 am
Post Big O
Started the ZF swap on TFB, yanked the auto setup out yesterday and started prepping the Bronco for the 3rd pedal. Found a couple of needed bits at the JY today, bolted the ZF adapter onto the D20 and unwrapped the rebuilt ZF. Time to sort out the ill fitting exhaust & fix that leaking oil pan gasket! New parts are so shiny.
Fri Apr 10, 2020 7:39 pm
Post Re: Big O
Do you still need a brake pedal? I think I have one.
Fri Apr 10, 2020 9:48 pm
Post Re: Big O
Sat Apr 11, 2020 7:51 am
Post Re: Big O
Free to a good home.Image
Sat Apr 11, 2020 8:01 am
Post Re: Big O
Excellent! Can you set it outside and I’ll work on a time to swing by.
Sat Apr 11, 2020 8:52 am
Post Big O
How do you start an engine w/out a trans bolted up so you can chase down the oil leak coming from the back of the motor? Well, you dig out an old bell housing that you just can’t throw away and bolt up the flex plate and starter and turn the key. Happy to report it isn’t the rear main seal, it was just the oil pan gasket failing again
Tue Apr 21, 2020 10:07 am
Post Re: Big O
LOL - that falls under the "You never know when you might need it" category. And so it perpetuates!
Tue Apr 21, 2020 10:54 am
Post Re: Big O
Happy to report the ZF-5 has been shoehorned in, 1” body lift for the win!
Poke -> Rox
Fri May 01, 2020 8:17 am
Post Re: Big O
With a 1" lift that's impressive! Nice job thumbs up
Fri May 01, 2020 2:31 pm
Post Big O
Back on the road today for a quick around the block run. The clutch master barely slipped in between the all other junk bolted to the firewall and inner fender. We’ve temporarily mounted the original shifter to the trans with a small adapter plate, he has plans for something better.
We have a few items to tidy up; clearance the x-member for the front driveshaft, swap hubs over to Warn, improve the new sheet metal for the trans tunnel, install the new twin sticks, etc.
Willem is one step closer to having the Bronco that he always wanted. Welcome to the 3 pedal world my boy!
Sun Jun 14, 2020 11:07 am
Post Re: Big O
That's great!! Welcome! Manual tranny's FTW!! LOL!
Mon Jun 15, 2020 6:48 am
Post Re: TFB SITREP
Willem’s stock Explorer PS pump was starting to fail & I never really like the Explorer reservoir either.
Upgraded to the Viper built PS pump & PSC res w/ 12AN sized supply line, because Justin can’t be the only guy with a big hose, ha!
Thu Oct 21, 2021 5:28 pm
Post Re: TFB SITREP
Good upgrade! I have 1 more of the brackets to attach the reservoir to the explorer bracket if you’re interested.
Thu Oct 21, 2021 6:10 pm
Post Re: TFB SITREP
How do you like the psc reservoir?
Thu Oct 21, 2021 6:24 pm
Post Re: TFB SITREP
Fri Oct 22, 2021 6:28 am
32,908,315 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
