www.ColoradoClassicBroncos.com - View topic - Oil Drain Plug Leak
It is currently Mon Nov 25, 2024 2:59 am
Reply to topic  [ 8 posts ]
 Oil Drain Plug Leak
Post Oil Drain Plug Leak
Just changed my oil and I have a slow leak around the drain plug. Was wondering if anyone has a hack or suggestion on re-installing the drain plug so this doesn’t happen?
Thread sealer?
Wed Apr 29, 2020 6:52 pm
Post Re: Oil Drain Plug Leak
Copper washer.
Wed Apr 29, 2020 7:20 pm
Wed Apr 29, 2020 7:26 pm
Probably not the “correct” answer, but Hack YES...
I have used the little rubber washer off of the garden hose, it’s size is just right and for 3000 miles you can count on it not leaking!
Thu Apr 30, 2020 6:21 am
Well, put the copper washer on and now it leaks worse. I haven’t even started the Bronco to pressurize it and in a day it’s leaked 3 times as much as it did before. So damn annoying.
Sat May 02, 2020 12:03 pm
Sat May 02, 2020 8:55 pm
Per a suggestion, I torqued the drain plug down to about 30lbs and no more leak! I tend to over tighten stuff so was very reluctant at first, not knowing how much I should be tightening it down.
Finally, an easy fix!
Sun May 03, 2020 5:55 pm
Tue May 05, 2020 1:13 pm
Users browsing this forum: No registered users and 35 guests
33,024,435 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
