Register •
FAQ
• Login
It is currently Sat Oct 12, 2024 4:20 am
[ 7 posts ] |
CamTheRam17
Joined: Wed Aug 22, 2018 2:38 pm Posts: 64 Images: 0 Location: Eaton
Rear Seat???
Hey, I don’t know if anyone had tried this but I have an original rear seat I’d like to mount but I’d also like to have no back seat so does anyone have any ideas for a quick release rear seat using the factory mounting holes?
_________________ 1973; 302; Mexican Block; Standard 3speed; lifted; 33's; Slotted mags; Bilsteins; Stroppe; Dana 44; Power Brakes; Power Steering; Cut; Retrosound
Sun May 03, 2020 12:05 am |
Re: Rear Seat???
It's 4 bolts plus seat belt mounts, so it's fairly quick release. I have not seen anyone with a stock seat make something like that, but I am sure it's out there.
Mon May 04, 2020 6:38 am |
Re: Rear Seat???
The first picture is the set up I had in my Bronco years ago, I just welded the Clevis (?) shaft upside down onto the stock rear seat bolt so it was sticking up through the seat frame and then just a cotter pins holding it in on all 4 corners...
The next 2 pictures...Would something like this work? These are expensive and the price is per piece so we’re talking around $200 bucks (for 8 pieces parts!) and I don’t think that’s worth it.
Would anyone know where to get something close to this set up (Last 2 pics) for way cheaper?
Mon May 04, 2020 7:15 am |
TOOLMAN
Re: Rear Seat???
I used something like this: https://www.amazon.com/Special-Products ... 02&sr=8-27 with some lynch pins and a couple washers. I just went down to a local tractor store and picked them up.
Mon May 04, 2020 7:16 am |
Re: Rear Seat???
Mon May 04, 2020 7:22 am |
Re: Rear Seat???
mcmaster may have more variety of options for that sort of thing too.
Mon May 04, 2020 7:53 am |
Re: Rear Seat???
Mon May 04, 2020 9:00 am |
[ 7 posts ] |
